Results 1 to 10 of 13
Thread: What button..
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    Default What button..
    If you highlight parts in your log, it highlights it in the table/s in your tune.
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
    In tunetool: goto Edit->Properties->Scanner and checkmark the 2 boxes under PID Linking.
    Also make sure that scantool Data tab shows same pid units as tunetool table axes.
    Mar 2008
    I had those on but didnt think it was working..
    Look here... See how I highlight the WOT only, it has its min/max values but on the tune it has the everything in the whole rows and not just only in the highlighted area. Is this just the way it is?
    Mar 2008
    I was wanting to get the commended AF to the WB02 a little closer under WOT so I was just going to add more in that specific area on the main ve table to do it. It would be easier if its was what I highlighted ONLY shows up in the tables/graphs.
    If you look carefully, you will see that B0101 highlights only the 15 kPa column (see the 15 in the column heading)...
    Goto the scantool DATA tab and look at MAP... what are it's units...?
    If they are psi, then goto the PIDs tab and set MAP to Metric (rightclick->Metric).
    Aug 2008
    Waterbug1999, in the TuneTool, 1)click on EDIT 2)Click on Properties 3) and in the scanner section make sure "RUNAWAY HIGHLIGHTING" is UNCHECKED.....
    and make sure "HIGHLIGHT SCAN TOOL IN TUNING TOOL MAPS" is checked...
    FLASHSCAN V2 & AUTOCAL
    Mar 2008
    The thing is, I am in 95 - 99 KPA and ~2300 to ~ 5200. So, why doesnt it only higlight that and what falls inbetween?
    I dont know why it highlights anything in the 15KPA column, im way up in the 90's.
    Mar 2008
    Quote Originally Posted by GAMEOVER View Post
    that did this... I dont know why its highlights anything in the 15kpa, my highlighted area on my log is in the 90's.
    Aug 2008
    In your data logs(scantool) make sure your PIDS match what you have in the Tunetool tables. Are you sure you're not logging MAP in PSI?
    Post up a screen shot of your Scantool PIDS...
    Mar 2008
    under my PID tab it has KPA & PSI.
  1. Button issue...
    By mike_s in forum FlashScan V2
    Last Post: February 11th, 2010, 06:47 PM
  2. Tow/Haul and/or Performance button
    By nonnieselman in forum Gen III V8 Specific
    Last Post: August 5th, 2009, 02:41 AM
  3. ctrl button ??
    By 2004gmc in forum FlashScan V2
    Last Post: May 10th, 2009, 02:46 PM
  4. logging button?
    By hot-dog in forum FlashScan V1
    Last Post: February 17th, 2009, 09:58 AM
