If you highlight parts in your log, it highlights it in the table/s in your tune.
1999 Trans Am. 10.71 @ 126 - stock bottom end-
In tunetool: goto Edit->Properties->Scanner and checkmark the 2 boxes under PID Linking.
Also make sure that scantool Data tab shows same pid units as tunetool table axes.
I had those on but didnt think it was working..
Look here... See how I highlight the WOT only, it has its min/max values but on the tune it has the everything in the whole rows and not just only in the highlighted area. Is this just the way it is?
I was wanting to get the commended AF to the WB02 a little closer under WOT so I was just going to add more in that specific area on the main ve table to do it. It would be easier if its was what I highlighted ONLY shows up in the tables/graphs.
If you look carefully, you will see that B0101 highlights only the 15 kPa column (see the 15 in the column heading)...
Goto the scantool DATA tab and look at MAP... what are it's units...?
If they are psi, then goto the PIDs tab and set MAP to Metric (rightclick->Metric).
Waterbug1999, in the TuneTool, 1)click on EDIT 2)Click on Properties 3) and in the scanner section make sure "RUNAWAY HIGHLIGHTING" is UNCHECKED.....
and make sure "HIGHLIGHT SCAN TOOL IN TUNING TOOL MAPS" is checked...
FLASHSCAN V2 & AUTOCAL
In your data logs(scantool) make sure your PIDS match what you have in the Tunetool tables. Are you sure you're not logging MAP in PSI?
Post up a screen shot of your Scantool PIDS...
under my PID tab it has KPA & PSI.
