Results 1 to 5 of 5
Thread: What is your idle AFR??? My car wll not idle?
    Jun 2005
    Default What is your idle AFR??? My car wll not idle?
    My car used to idle with an AFR of about 11:1. Now I leaned it out to about 13:1 and it will not idle anymore. I tried taking air from the IAC in park/in gear and it did not change??
    Any advise? Kind of embarrasing having an 800 hp car that will not idle!! :oops: :(
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
    Senior Member dissonance's Avatar
    Sep 2003
    Are we talking warm up? Or normal idle? I was messing with my ve tables today and noticed with the stock ve +15% "mafless at the time" and my car was idling at 17:1 with no problem...
    I think warm up afr is some place around 13.5:1 "stock" and maybe 12.5:1 on a colder start. So it should idle fine @ 13:1... Sounds like something else maybe wrong and adding more fuel is keeping the car running.
    What kinda timing are you running at idle? I don’t know a lot about FI so it maybe related to that or the idle afr should be something different then an N/A car.
    Jun 2005
    I cannot remember for sure. But I think it is at about 22 degrees at idle. I would have to look for sure. I got the timing tune from Wait4me. It idles better with his idle table then the stock, with the stock it roamed. But after I leaned out the idle, it just dies. I guess I just have to keep messing with it. I just wish I new exactly wich direction I should go with certain things.
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Oct 2003
    Default Re: What is your idle AFR??? My car wll not idle?
    Quote Originally Posted by nitrorocket
    I'm not sure exactly what you mean when you say AFR. When you say the car would idle at 11:1, do you mean comanded or actual?
    Jun 2005
    11:1 AFR(AIR FUEL RATIO). That was actual AFR. Commanded is 14.7:1.
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
  1. Car Wont Idle And Runs Rich At Idle ( Tune Inside)
    By mikeyayell in forum Gen III V8 Specific
    Last Post: January 8th, 2008, 03:17 PM
  2. Idle/Idle Transition Tuning
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 11th, 2007, 04:10 AM
  3. Stock maf = perfect idle. Big maf = unstable idle. Any tuning suggestions?
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: July 11th, 2006, 02:58 PM
  4. Desired Idle Speed and Idle Airflow
    By Bowtieman in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2006, 10:07 AM
  5. I cracked the 96 lb injector idle AFR!!!! Now it wont idle!
    Last Post: October 13th, 2005, 11:09 AM
