Results 1 to 5 of 5
Thread: 0202005 is based on what OS?
    Jul 2003
    Default 0202005 is based on what OS?
    Nov 2006
    Do you mean 2020005?
    020200xx = 12212156 ('02 Fbody)
    LC-1 WBO2
    That is correct.
    Jul 2003
    hm.. i am using it on a z06 w/o issues
    2002 Corvette also used 12212156, so it should work fine.
  1. Coolant based fueling
    By Highlander in forum Gen III V8 Specific
    Last Post: July 20th, 2009, 07:16 AM
  2. Torque Based Fuel Tables LBZ
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 2nd, 2009, 11:22 AM
  3. PE modifer based on RPM Lambda
    By SHOGOR in forum Gen III V8 Specific
    Last Post: July 19th, 2008, 05:57 AM
  4. B3618 PE based on RPM
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: April 22nd, 2006, 08:38 AM
  5. 2step Timing Based vs Fuel
    By MN C5 in forum Custom Operating Systems
    Last Post: February 20th, 2006, 05:03 PM
