Results 1 to 7 of 7
Thread: PLX>Flashscan V2 install
    Nov 2006
    Default PLX>Flashscan V2 install
    I've looked everywhere on how to install a PLX SM-AFR to V2 but cannot find anything as far as wiring goes.
    I've tried to register at PLX forums and each time I get php error codes.
    What wires go from where to where from the PLX to the V2?
    Thanks for any and all help.
    This does not help
    http://forum.efilive.com/showthread.php?t=81
    Nov 2006
    I wouldn't think that thread would help,
    it's about 2 years older than the V2.
    If you want serial WBO2 connection you will need to do some hacking
    PLX SM-AFR Serial upgrade
    LC-1 WBO2
    Nov 2006
    Not a big fan of soldering into a part I just paid $200 for.
    There are so many people out there using PLX. There has to be an easy way to hook this thing up.
    If you want serial AFR (recommended), then follow Mr.Prick's link.
    Otherwise if you want analog AFR, connect the PLX's analog signal output to FlashScan's AD1+ input and the PLX's signal ground to FlashScan's AD1- input.
    Nov 2006
    I'm a visual person.
    Would this be correct doing an analog setup?
    Yes that is correct (the red and black ones).
    Nov 2006
    Thank you
  1. PLX install completed in preparation for Flashscan!
    By AllCammedUp in forum General (Petrol, Gas, Ethanol)
    Last Post: October 26th, 2008, 05:42 AM
  2. Cannot Install
    By NAH in forum FlashScan V2
    Last Post: December 7th, 2006, 09:09 PM
  3. LC-1 install.
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: August 31st, 2006, 09:40 AM
  4. Where to install LC-1?
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: August 2nd, 2006, 02:56 AM
