Results 1 to 4 of 4
Thread: LMM defuel
    Default LMM defuel
    This has been talked about one other forums before with no solution. This is for sled pullers with the LMM. How do you get the defuel right for smooth shifting??? I haven't talked to one person yet that has this figured out. It doesn't matter if you have a built trans or not, they shift like crap in 4lo with a sled hooked behide you. It feels like the truck is going to break inhalf. It doesn't matter who's tune I use they all react the same. Anyone with a LMM, that pulls, have smooth shifting tune? Is there something missing in EFI Live, like the low range rev limiter issue in the past? Any help?
    Mike
    Senior Member DmaxHawk's Avatar
    Apr 2008
    Are you adjusting your ECM or TCM tune?
    07 El Bee Zee
    Little faster than stock...
    both
    Jan 2006
    are you logging the shifts? Post it here.
    Custom Tuning Services
  1. Defuel affect
    By SGFastMax in forum Duramax LB7
    Last Post: May 5th, 2010, 11:59 AM
  2. defuel question
    By saltflat in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 2nd, 2009, 06:41 AM
  3. LMM: Strange defuel
    By JoshH in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 28th, 2009, 04:00 PM
  4. Killing Defuel?
    By Cougar281 in forum General (Diesel)
    Last Post: October 25th, 2007, 06:05 AM
