Results 1 to 6 of 6
Thread: Fuel Trim help needed, please advise
    Apr 2009
    Default Fuel Trim help needed, please advise
    Hey Guys, I ditched my FAST92 and started over with stock tune. Been thru AutoVE and AutoMAF ( both table and maf tuning with LTFTrims disabled ) car idles great, commanded afr following actual, less than 1 degree knock at up to 120mph.
    Set all parms back to normal so VE and MAF and Fuel Trims and DFCO are all running again. Now my LTFuelTrims are between 15 and 20 most the time. Heading to track Saturday and need to whip this tune into shape.
    Should I do some more AUTOMAF runs with the Fuel Trims left on this time or what?
    2001 Corvette Z06
    Apr 2009
    Default Used search, added more info, still need guidance
    Found a post by Mr Prick about some calc_pids and added them. I was already logging LTFT's so they show up. I created a couple maps using his new LTFT Ben and LTFT Avg PID's as shown below. This was a very freeway type cruise home mostly idling along, so not real valuable.
    Seems to me that the AVG map is saying the LTFT are having to add a bunch of fuel all the time.
    The FT Ben map seems to be saying I need to paste and multiply to b0101 to bring in more fuel, most cells around the 1.2 multiplier range.
    Few questions
    When I went thru AutoVE speed density mode I had b0101 with .01, why the digression???
    b0101 isn't going to be my key factor at the track as I'll be running over 4k rpm and foot in the pedal coming out of turns. Wont I be running MAF most the time?
    Thanks in advance, Ken . . .
ID:	6062   Click image for larger version.
    Apr 2009
    Seems I did my AutoVE in open loop and never went back thru the VE part after going back to closed loop with the LTFT enabled. I see now that I have to do that.
    2001 Corvette Z06
    Nov 2006
    Those LTFTs are high, if everything is configured right and
    you don't have an intake or exhaust leak it is probably because
    you tuned in OL then re-enabled LTFTs.
    Tuning in OL makes the VE lower than it would be in CL.
    Having gone thru the whole AutoVE thing and not understanding why
    AFR was always lean at cold start and when IAT got above 95°F or
    rich when ECT and IAT dropped after the engine warmed up, I bought a RR.
    With the RR I could see how much higher cold start VE values would be then gradually go down as ECT got higher,
    sometimes they got very low, lower than my minimum limit.
    They where never a constant reliable value in OL always up and down
    to get that perfect 1.00 BEN.
    After OL tuning and re-enabling LTFTs I also noticed cold start was still lean
    and LTFTs would be quite high.
    I then decided try using LTFTs and WBO2 for VE tuning, this richened cold start AFR and got VE value to where LTFTs would be in the magical 5% to -5% range, no more positive LTFTs at WOT and as a bonus VE was smooth.
    IMO
    OLSD is good for getting a general shape of the VE.
    Once this is done add X% to VE and then use LTFTs.
    LC-1 WBO2
    Apr 2009
    I do have a question in general.
    Looking at the same log file
    Map Wideband BEN says I should barely up the fuel
    Map LTFT Ben says multipley by 1.20 in most cases.
    I can see how doing the LTFT tuning will no doubt reduce the need for the fuel trims to help out, but wont adding all that fuel to the VE table cause my actual AFR to no longer follow commanded?
    Seems like two evils competing. I need actual following commanded, but I also want those fuel trims down to zero. How is that going to happen?
    Nov 2006
    That's because LTFTs are keeping AFR near stoich.
    You will still be near stoich after making changes with it (LTFTBEN),
    AFR will not be affected too much in CL.
    AT cold start you will be richer.
    In CL the NBO2s keep AFR to what {B3601} is set to,
    if LTFTs are highly positive before PE you will get LTFTs during PE.
    This will usually make you rich.
    When they are 0 in PE AFR will be close to commanded provided
    VE is proper in those areas.
    It will work if you use the filters,
    don't change the same cell(s) with both BENs.
    LC-1 WBO2
  1. Fuel trim cell boundries / zones?
    By JAY4SPEED in forum E37, E38 & E67 PFI ECM's
    Last Post: September 21st, 2009, 03:00 PM
  2. Fuel Trim Cell Issue with 7.5
    By MoTruck in forum General
    Last Post: February 2nd, 2008, 05:26 AM
  3. Fuel Trim Cell PID
    By VetPet in forum Petrol / Gas
    Last Post: April 9th, 2007, 05:24 PM
  4. LS2 fuel Trim Cell# and Engine Zone1_DMA
    By MICK in forum Gen IV V8 Specific
    Last Post: February 22nd, 2007, 03:59 AM
  5. Fuel Trim Cell 10
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: December 20th, 2005, 11:24 AM
