Results 1 to 3 of 3
Thread: Minimum Idle Airflow Tables
    Jul 2009
    Default Minimum Idle Airflow Tables
    Can someone explain to me what the minimum idle airflow tables do. They are for all gears and go out to 7000 rpm on the LS7. What does 7000 rpm have to do with idle? And why is there a table for each gear? I'm having surging problems at low speeds with the mild cam I've installed, and I'm told that adjusting these table upwards will cure the surge. Before I make any changes, I would like to have some idea as to what I'm doing with these tables.
    Apr 2009
    The table doubles as both base idle airflow and throttle follower at higher RPM. You run slightly higher airflow minimums at elevated RPM to get a dashpot effect to control coastdown and prevent stalling on decel or declutch events. Automatics sometimes use different airflow targets in high gear to prevent tip-out clunk.
    The base values near idle speed need to be calibrated to match whatever stable airflow your engine requires to idle. Keep in mind that several other adders can be applied to this for other things like A/C, temperature, etc. You'll also need to make sure that your AFR control is good before using current actual airflow to solve for your running airflow at idle or coastdown.
    ~Greg
    Calibrated Success - EFI Training and Tuning Done Right
    GM Beginner's Guide DVD available now through Summit!
    Engine Management: Advanced Tuning - Amazon's best deal for the EFI crowd.
    Jul 2009
    Thanks. That gives me a little better understanding of it.
  1. Idle Base Spark P/N and minimum advance
    By efizjb in forum Gen III V8 Specific
    Last Post: June 23rd, 2008, 03:35 AM
  2. Help with airflow tables, Please!!!!
    By DWS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 16th, 2006, 10:59 AM
  3. Desired Idle Speed and Idle Airflow
    By Bowtieman in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2006, 11:07 AM
  4. Is there a way to make the pcm use the p/n idle airflow tables?
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: December 26th, 2005, 03:11 PM
