Results 1 to 10 of 14
Thread: New updated 2010 Camaro tune file?
    Mar 2005
    Default New updated 2010 Camaro tune file?
    I have been reading some people have been complaining about their early L99 cars not running as good as they should with 6 to 7 second 0 to 60 times (GM says 4.7 sec.). Later ones seem to be ok.
    Some have read the later files and said there were several changes done to the tune to correct this.
    Does anyone have a later tune file (around 30,000 & up vin) that they would share with me or post it up? I posted my early one, vin 3xxx, in another post. Inquiring minds just want to know.
    Ron
    2014 Silverado 4X4 6.2L
    2010 Camaro 2SS-RS L99
    2007 Sierra Denali 6.2L
    2005 1500HD 4X4 Quadrasteer 6.0L, COS3 SD
    Dec 2007
    Quote Originally Posted by RonC View Post
    Ron
    Curious about this change too. Certainly the timing table has a strange ripple in it where it jumps up and back 4 or 5 degrees.
    Octane scaling rather aggressive too. 50-70% more than typical.
    Oct 2005
    Sounds like Torque Management to me.
    Check the trans tunes too.
    2014 VF SV LS3 Maloo.
    Mar 2005
    I have seen where some have pulled the ECM fuses #5 & 20 to reset it and have had good results. What would be reset in the ECM to do that? Octane scalar? LTFT's? Anything else that would do this?
    Link http://www.camaro5.com/forums/showthread.php?t=38964
    Another thought. What happens if you do the same thing to the T43 trans?
    Dec 2007
    Yes the Octane scaler returns timing to the hi octane table with a power down. Trims yes also but the would need to be out substantially to make a difference. Cant imagine that on a new car. T43's dont seem to show any effects from power downs.
    Mar 2005
    Do you know what resets the scalar normally in the E38's? Fuel refill, restarts, so many heat cycles, etc?
    Dec 2007
    Lack of fast knock will see it incrementing (decrementing...) back toward the hi octane table.
    Mar 2005
    Within what time frame does this happen? Same heat cycle or over a longer time?
    I just noticed the Octane Scalar pid in the scanner but I have never logged it. It should tell you where it's at while logging.
    My Camaro probably had this poor performance when I got it because it would not spin a tire with the TC off. After 3 weeks I couldn't stand it anymore and started tuning it. It will spin the tires now.
    It would be interesting to log the scalar on one of the cars with this problem.
    Dec 2007
    Have never bothered to wait and see how long it took to get back to the top table.
    Always powered down the ECM or simply copied the top/hi table to the low table.
    It does depend on the difference between the two tables and the "decrement rate" which does not appear to be in the Camaro OS. Having watched it on a few logs (and given up waiting LOL), I would guess that in 20 miles it may be back to normal, and recall it that it may return on a tank fill, though that may be hearsay. Someone may chime in and confirm.
    It appears GM may be on their 4th OS to date:
    12632464
    12633056
    12635166
    12635863
    Though 12633056 isnt even listed. But does turn up in cals.
    As you may head read elsewhere, GM knows they have a problem with this and is making solid efforts to get on top of it, so why not report it to you dealer and get them to fix it. (after you flash your original tune back in ).
    Dealer may even have some good intel. They have been through 5 engine calibrations, and the last was to improve misfire detection, so maybe that has something to do with the issue.
    Cheers.
    Mar 2005
    Mine is the 12633056 OS. Does anyone have a file of any of the others? Do the manuals have different OS's? I guess no one has a "late" OS file?
    I kept the hi/lo tables the same when I was working on the 91 oct or 87 oct tunes. I did the 91 tune first and when I finished tuning for 87, I then put the 91 table back in it's place. It really runs well on 87, even better than stock with 91. 93 oct. is not available here.
    I have read that there are updates available but they hook up the car to their database to get them and GM can tell if the ECM has been re-flashed as it keeps records of sorts. Mine would not match up with theirs, I'm sure. I am going to leave the sleeping dog alone on this one.
  1. How can I run 2 computers in a 2010 camaro one stock & one with a tune ????
    By 2010 Bumblebee in forum E37, E38 & E67 PFI ECM's
    Last Post: May 4th, 2010, 11:20 AM
  2. 2010 Camaro ss factory tune
    By 2010 Bumblebee in forum General (Petrol, Gas, Ethanol)
    Last Post: April 29th, 2010, 07:17 AM
  3. Looking for Vendor to Tune 2010 Camaro
    By Gas Sucks in forum E37, E38 & E67 PFI ECM's
    Last Post: February 17th, 2010, 08:08 AM
  4. Need Stock 2010 Camaro file ASAP
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: November 11th, 2009, 06:11 PM
  5. 2010 Camaro SS Auto, Magnuson tune file
    By general23cmp in forum E37, E38 & E67 PFI ECM's
    Last Post: October 19th, 2009, 09:04 AM
