Results 1 to 10 of 10
Thread: Script process update request
    Lifetime Member vortecfcar's Avatar
    Apr 2007
    Default Script process update request
    In future releases of the software, can we please have the software continue to run the script after it encounters errors like this instead of stopping. It would make scripts a lot more user friendly. I thought it was fixed in an older release, but may have been reactivated ??
    That has now been updated for the next release.
    Any error will cause only that particular calibration update to fail, the script will progress on to the next update.
    A warning/error message will be displayed for each error that is encountered.
    Jan 2004
    Another request that falls in the same lines. Can you add a button at the bottom that says maybe Run New or something along those lines. This way we can run another script right away rather then going through the other steps. The button would take you back to the navigation window that lets you select the script to run. Make any sense??
    Already done.
    Nov 2006
    I got this error running one.
Name:	Script Error.jpg
    It seemed to run the complete script but some values were not right.
    LC-1 WBO2
    Quote Originally Posted by mr.prick View Post
    Does it fail with the same message every time?
    If so, please send the script and the *.tun file on which you were running the script so I can try and reproduce it here. (send to paul@efilive.com)
    I'm working on it.
    Nov 2006
    The last update fixed scripts for me.
    LC-1 WBO2
    Lifetime Member IdahoRob's Avatar
    Apr 2006
    fixed for me also.
    2013 LML, 550hp with factory emissions, stock cp4 and compound turbos.
    2002 LBZ, 4x4 (Max'd Out) 6000lbs 9.36 @ 154 mph NHRDA Champion and Record holder
    1965 El Camino, duramax 9.6 @ 149MPH
    All EFI tuned by Adrenaline Truck Performance
  1. Update Request
    By swingtan in forum Black Box Logging
    Last Post: July 14th, 2009, 03:05 PM
  2. Can someone help me set up RAFIG process?
    By Slow73 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 4th, 2009, 02:49 PM
  3. RAFIG process.. How's it done...
    Last Post: March 20th, 2008, 09:29 PM
  4. Auto update request!!!!
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: January 25th, 2007, 01:50 AM
