I am at my wits end. My project is finished but I have no throttle. All the parts are from a 2004 silverado except for the TCM module. The engine is a 4.8 v8, 2004 silverado 4.8 ecu. The throttle controll module is from a 2006 silverado. I bult the wiring harness myself. The ecu was reflashed by a friend of mine at superchips in Orlando.
The truck is a 1996 s15 jimmy.
The truck starts right up and runs perfect. I have no throttle at all. The codes I pulled are a p1125, a p2120, and a p2125. I have checked every wire. I have checked all voltages with a scan tool. I have checked voltage and resistance with a multimeter.
APP sensor 1 is .57v @ idle and 3.87 at wot
APP sensor 2 is .56v @ idle and 3.87 at wot
sensors "AGREE" according to the scan tool.
If I clear the codes they come back imediatly
my PCM service # is 12586242 and the hdw # is 12583660
the TAC module # is TM01-160K1
the # under that # is 508-018930
the APPS # is hard to read but looks like # 010504-00360-4
the only # I see on the throttle body is 13z022
is it possible that the APPS is bad? I am on my 3rd TAC module. I am desperate for answers.
Edit/Delete Message
