Results 1 to 6 of 6
Thread: Help!!
    Aug 2009
    Default Help!!
    I just got efi live and i downloaded everything. i went to plug it into my truck and i cant load the ecm stock file. none of the three are highlighted. please help!! and i tried unplugging the ecm and plugging it back in
    Apr 2008
    Does the Flashscan display start up if only plugged into the OBDII port?
    If not cigarette fuse may be blown.
    Do you have the key in the run position.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
    Aug 2009
    everything starts up fine on the screen. just i cant use any of the 3 upload buttons
    Nov 2006
    Have you entered your license info?
    When the RR tool bar is displayed there is another set of the "upload buttons" visible,
    the RR buttons will be greyed if you are not connected to it.
    Try hot keys:
    Read = Ctrl+PgUp
    Program Calibration only = Ctrl+PgDn
    Program Calibration and Operating System = Ctrl+Alt+PgDn
    LC-1 WBO2
    Aug 2009
    how do u enter license info? and where is thr rr toolbar?
    Nov 2006
    Quote Originally Posted by DmaxLb7 View Post
    Help> Register EFILive
    You will get a notification when opening scan or tune if the software is not registered.
    > > > RoadRunner FAQs < < <
    You should still see the green and red buttons for "standard" PCM read/write if the RR tool bar is displayed.
    LC-1 WBO2
