Hey guys,
Let me first start by saying that I have downloaded V8 (but currently still using my V7.5.5 until V8 is fully updated to imperial) and last I knew was totally updated until about 2 months ago and since then I've not been able to get the downloads bc we just moved to a new home and just got the net hooked up but all we can get is dial up and my laptop doesn't have a connection port for a standard phone line... but have the updates been made to change the PID's to imperial yet? And when I connect my scan tool to my ecm and select the PID file it says something about .pmm has incorrect CRC or something to that effect, not sure what that means?
Okay now on to my main question...didn't the LBZ have the PID capable of measuring actual boost not just desired boost, or boost+baro pressure? I thought there was a PID that calculated actual boost pressure as shown on a boost gauge in which the Baro pressure was subtracted out. But now it doesn't function on my V7.5.5 scan tool. It only has the PID that corresponds to the ECM desired boost tables which include Baro pressure.
The reason I ask is bc I have a boost gauge from Dakota Digital and it's not calibrated right...I'm on my third sending unit and second gauge and they still can't get it right so I was wanting to show them some screen shots from EFI live against their gauge's reading. When I power the gauge with the engine off it gives a reading of 14psi (should be 0psi) which means it's detecting Baro pressure somehow bc my scan tool at that time displays 14.1 as the barometric pressure. When I start the truck and rev it up to about 1500rpm in park the gauge reads around 16psi of boost, but it SHOULD be reading 2psi of boost bc the 14psi of barometric pressure shouldn't be included in the reading of an aftermarket gauge. At that rate my gauge would read 35psi of boost on a stock turbo and stock tune...you see my frustrations? lol
