Results 1 to 3 of 3
Thread: upgrade from 2000 o.s to 2002.os
    Lifetime Member smslyguy's Avatar
    Oct 2008
    Default upgrade from 2000 o.s to 2002.os
    how do you upgrade from a stock 2000 gmc to a 2001 or 2002 o.s? This is a stock truck i was just wanting to get more tuning options from the 2002 o.s, but don't know how or where to find them.
    2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
    Now own a 2015 1LE camaro
    Nov 2006
    LC-1 WBO2
    Lifetime Member tokymon's Avatar
    Apr 2008
    go to holden crazy and download a stock program from a 2002 that is the same as you'res (ei. 02 gmc 5.3l/4l60/4x4) and flash the os in as full flash not just the calibration.
    97 2500 ecsb 5.7l/4l80e/4x4 411 pcm /thorley tri-y's/dual super 40's with x (catless)/aem cai/msd 6a and coil/zz4 cam/beehive spring/lm-1
    stock sucks
  1. Anyone done a Corvette 2000 OS to 2002 OS change?
    By aleco99 in forum Gen III V8 Specific
    Last Post: September 24th, 2007, 01:24 AM
  2. Does any body have a OS 2000 to 2002
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: August 21st, 2007, 08:40 AM
  3. Going from 2000 to 2002 OS problem ?
    Last Post: June 9th, 2007, 10:00 AM
  4. ? ON CUSTOM O.S. & 2000-2002 FLASH
    Last Post: September 6th, 2005, 02:30 PM
  5. I have a 2000 F-Body; should I change to a 2001 or 2002 OS?
    By leres in forum General (Petrol, Gas, Ethanol)
    Last Post: August 26th, 2005, 05:44 AM
