Results 1 to 10 of 11
Thread: Error message?
    Mar 2009
    Default Error message?
    Ihave a holden commodore vx ss(most gm stuff is probably the same but just in case) when i turn my car on the instrament clustor displays error for about 10 sec then goes away. only noticed it since started tuning anyone know what that could mean. everything seems fine.
    Oct 2006
    Are there any error codes showing in your logs?
    The Tremor at AIR
    Mar 2009
    not that i have seen, the errors come up automatically when you connect and log yeah? i dont have todo anyhting special?
    Jan 2007
    You need to click on the little picture of a 'red' motor in the tool bar of the scan tool to display any codes.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Mar 2009
    It had a "powertrain control module(PCM)" $10 fault? how do i tell what that is?
    Oct 2006
    Quote Originally Posted by nathans1987 View Post
    That I dont know. Hopefully Ross, Paul or Joecar can help on this one.
    The Tremor at AIR
    Mar 2009
    i might reflash the whole cos 3 maybe it got corrupted somehow :s drags start tonight hope it dosent effect me.
    I notified Paul about the error message on the instrument cluster.
    Module $10 is the PCM.
    When you click on the red motor button like hquick said, the scantool should also show you the DTC... post a screenshot.
    It seems to me that your IPC displays "Error" to let you know there's a current DTC...
    See attached image (sorry for the hurried sketch), scroll down carefully, look for the DTC's with coloured icons, these are the ones that are active... the legend tells you what the DTC state is.
Name:	Reading DTC's.png
    On the DTC subtab, you should see one or more active DTC's...
    What are their codes...?
  1. Got the aem w02 pid working but ben has error message
    By MattysTA in forum General (Petrol, Gas, Ethanol)
    Last Post: August 28th, 2009, 01:12 PM
  2. Error Message when trying to update
    By MN C5 in forum FlashScan V2
    Last Post: April 5th, 2009, 12:07 PM
  3. Error message formatting....
    By Lennart in forum FlashScan V2 BB Logging
    Last Post: March 27th, 2008, 11:34 PM
  4. Error message
    By Chevy366 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 20th, 2007, 10:48 AM
  5. Error Message
    By TNRGreene in forum General (Diesel)
    Last Post: June 13th, 2007, 11:30 PM
