Results 21 to 30 of 47
Thread: slow tune!
  1. #21
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    Quote Originally Posted by projectblackbird View Post
    no i don't have a wideband on the car. and as far as loading tunes, i'm not, just doing some comparison! this is how i'm learning to use this tuner so far! its like answers in the back of the book! lol
    Next thing you should get is a wideband in your car... That will tell you where your A/F is... Your too rich or too lean, that will leaves power on the table and could possibly damage things.
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
  2. #22
    Junior Member projectblackbird's Avatar
    Aug 2009
    its in the making, but i really wanna upgrade my pcm to a 99 like yours! i was told that i could get better tuning out of it
  3. #23
    Yep do the 99-02 PCM conversion then run COS 5 for when you go to spray. Flip a switch and the PCM instantly pulls however much timing you setup so you can spray all day long then go back instantly to full power N/A.
  4. #24
    Mar 2008
    You care to go into more detail about COS 5.
  5. #25
    Oct 2006
    COS5 has nitrous tables that are activated by earthing a pin in the PCM. Once the pin is earthed timing can be pulled from one table & fuel added from another if you are running a dry shot. Check out A0015 & A0016 in the attached tune file.
    This pin can also be set up for valet mode.
    IIRC the A0015 VE multiplier table will not work if the maf is enabled.(SD mode only)
    The Tremor at AIR
  6. #26
    Mar 2008
    Quote Originally Posted by 5.7ute View Post
    So you have A0015 that can richen up the AF by changing the VE Tables and A0016 can pull timing.. Pretty nice...
    Is there a limit to how much timing can be pulled and how much you can adjust your VE Table??
    That would be pretty sweet because there has been a countless number of times where I was either a tad too rich or a tad too lean and did not have the proper size jets to accomidate for it. So, this would come in handy for fine tuning. And since my motor crapped out on me a few weeks ago and I am going FI now, it looks like I should upgrade too.
    What all is needed to do this?
  7. #27
    Oct 2006
    I believe the VE multiplier has been upgraded to run at least a 300 shot. I know a few cars in Adelaide are running a 250 dry shot using only these tables.
    Check out here http://forum.efilive.com/showthread.php?t=2599
    The Tremor at AIR
  8. #28
    Mar 2008
    technically if you have a wet kit and use that table to mostly add fuel its a dry shot I suppose..
    Just make sure your injectors are up to par if you dont use your jets to get you close.
  9. #29
    Aug 2009
    hey, i did a little data logging today with your touch up! it was pulling 4degrees out between 4 and 5 grand
  10. #30
    Mar 2008
    98's tend to get high KR.... Put the old tune back in and see if you still get knock or throw some race gas in and see.
  1. Slow o2 crazy afr
    By wadesns in forum Gen III V8 Specific
    Last Post: May 23rd, 2009, 06:53 AM
  2. P12 slow read
    By Chevy366 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: August 3rd, 2008, 05:56 AM
  3. Slow scanning now
    By thunder550 in forum General
    Last Post: May 8th, 2008, 07:47 AM
  4. V2 really slow when by itself
    By minytrker in forum FlashScan V2
    Last Post: July 9th, 2007, 04:33 PM
  5. slow logging
    By SS2win in forum General
    Last Post: May 15th, 2005, 01:55 PM
