i have a 98 ws6
234/248 cam
595/605 lift 113lsa
longtubes and y-pipe
3600 yank
3.73 gears
ls6 intake
cnc'd heads
slp lid
can some one please tell me where i went wrong in my tune? my best time is only 13.81! the stock car with 171k on it went 13.83.
i have a 98 ws6
234/248 cam
595/605 lift 113lsa
3600 yank
3.73 gears
ls6 intake
cnc'd heads
slp lid
I see 18* for timing in the WOT area in your spark tables. So, just wondering why it got set like that.
1999 Trans Am. 10.71 @ 126 - stock bottom end-
i think it was set back for nitrous! but even i don't pull that much out for my big block
do you mean like a msd timing twister? i was spraying the stock setup with no adverse effect! do you think it needs to be retarded? if so how far? i only take out 10-12 for a 300 shot on my big block.
i sat here most of the day copying all of his tune to a stock tune except for the spark tables! i don't know much at all about this type of stuff but i think i should see a pick up in something or blow up trying
You are most definately leaving power on the table with only 18 deg advance at wot. Like waterbug has said boost your timing up at wot starting at 25 deg. I wouldnt go much further than 27 without a dyno or knock phones though.
The Tremor at AIR
thanks 5.7! do you think that stock spark table will work for some motor passes
