Results 1 to 5 of 5
Thread: DTC HOLDEN VS
    Sep 2005
    Default DTC HOLDEN VS
    HI all, just ran into something interesting during the week, i logged a DTC on my 1996 VS calais S/C, however efilive does not display what fault code it is using the vsv6.xml, but it does show that its trigged a DTC, the DTC tab goes red, and status flag shows 1 for "malf". If i load the VTV6, or VYV6.XML, and load my saved log then click the DTC's it shows a CODE 21 TPS HIGH. I didnt extract the code using the pin 5 6 on the connector as i cleared the code from efilive (should of done it) im trying to get the car to do the same fault.
    Short desciption of fault,
    1) Crusing at approx 60kph, revs suddenly drop to about 300 and CEL comes on then fixed itself up within 2 sec
    2) Was idling at a set of traffic lights suddenly revs drop to about 300 (almost stall) then pick up again
    So yea twice this fault, cant get it to happen again.
    Were you logging the macro: "DATADTC" or just "DATA".
    If you log just DATA then you won't see the actual DTC codes
    If you log DATADTC you will see the DTC codes.
    If you were logging DATADTC and the code did not show up, send the log file and I will extract the code manually and tell you what it was.
    Sep 2005
    email sent to efilive@blacky.co.nz hope thats right, if so the log is of the second time it happend, the spikes you see in the log are when the fan comes in and out, seems to cause stress to the data at those points, at the end is when it happend and it stopped recording.
    Cheers
    Quote Originally Posted by vsboost
    Cheers
    I've got the file - thanks. I'll let you know what I find tomorrow.
    For the sake of other readers...
    Trouble code 65 is set in that log file. It doesn't show up because it is listed as "Unused".
    To make the "Unused" codes show up in cases like this, just change the Unused text to be something other than Unused, for example Unknown. That way it will show up and you will see the code. However, it doesn't tell you what the code means.
    I looked up the trouble codes in the VT (next model) since newer codes are usually available in the later model definitions. However, there is no guarantee that the codes in the VT are the same as the VS (but they usually are).
    65: Left Hand O2 Sensor Rich
    66: Left Hand O2 Sensor Lean
    67: Left Hand O2 Sensor Open
  1. Holden E38 Files
    By RonC in forum Gen IV V8 Specific
    Last Post: August 18th, 2022, 06:25 PM
  2. Holden V8 - reluctor 24x with LS1 PCM
    By Batman in forum Conversions / Aftermarket Parts
    Last Post: July 21st, 2009, 05:36 AM
  3. PE in HOLDEN VE L98
    By vessv73 in forum Gen IV V8 Specific
    Last Post: May 19th, 2009, 12:11 PM
  4. holden VY V6
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2007, 04:38 PM
  5. Holden VE which ECM?
    By ringram in forum Gen IV V8 Specific
    Last Post: March 5th, 2007, 08:39 AM
