Results 1 to 6 of 6
Thread: Spark Advance vs. Gear or MPH
    May 2008
    Default Spark Advance vs. Gear or MPH
    I have a 99 Corvette with Custom OS 02020005. My problem is that I get some knock when in boost but typically only in 5th gear or higher. Is there a way to pull more timing out based upon what Gear i am in or based upon MPH? Maybe a clever way to use the N2O timing table ... such as some sort of switch that could indicate I'm in 5th or 6th and use that to trigger the N20 timing to pull out more advance?
    Appreciate any clever insights you might have!
    Thanks,
    Bobby
    Jul 2003
    No,
    I have asked for this, but in the end it's not that needed.
    Mar 2007
    you could set up the nitrous/valet switch to do it.....Im thinking of even manually flipping the switch at the track in 3rd gear
    Jul 2003
    That would be really cumbersome and not a seamless solution.
    Mar 2007
    well do it by iat or something......i dont think its that cumbersome....i swap boost settings on my 9 sec car going down the track often
    Jul 2003
    IAT no.. the best solution would be coolant temp.
  1. spark advance question
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: November 1st, 2011, 07:45 PM
  2. 98 350, spark advance?
    By 06bowtie_guy in forum Vortec V6/V8 Specific
    Last Post: December 7th, 2009, 09:23 PM
  3. 454 strange spark advance
    Last Post: September 8th, 2008, 08:38 AM
  4. Help my spark advance is too high
    By Big Block in forum Custom Operating Systems
    Last Post: April 25th, 2008, 04:48 PM
  5. Why so much spark advance?
    By Spdfrk1990 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2007, 07:13 AM
