Results 1 to 5 of 5
Thread: HELP! cant change the OS`s over how do I do it?
    Sep 2009
    Default HELP! cant change the OS`s over how do I do it?
    I have OS 12604138 and want to change some tune files to OS 12616698 . their used to be a video presentation on how to do it but that site took it down I guess. I have tried the way that I know how thru script but it dosent seem to work! any help guys would be great and I am running EFI V7.5.5 build 88 and once again thanks in advance guys
    Apr 2008
    You need a stock tune of both OSes you mention. Then load the stock tune of the 4138 and then load a comparison tune you want. Create a script from that. Note keep everything in Imperial format. Then exit that and open your stock 6698 tune and run the script onto it. Save it and ready to upload to ECM.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
    Sep 2009
    I think I forget to put it in imperial thanks again for the info
    Sep 2009
    yeah I tried that and still nothing. what else could I be missing?
    Apr 2008
    Are both those tune versions from the same generation Duramax engine. I am unfamiliar with OS versions beyound LLM side.
    Brian
  1. can i change the VIN in 05 LLY TCM ????
    By MARC75 in forum Allison 5 & 6 Speed
    Last Post: May 26th, 2009, 06:33 AM
  2. can i change my vin with EFI
    By MARC75 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 14th, 2009, 12:03 AM
  3. Cam change
    By jfclubby in forum Gen III V8 Specific
    Last Post: June 10th, 2008, 08:34 AM
  4. How to change AFR?
    By mikeyayell in forum Gen III V8 Specific
    Last Post: December 17th, 2007, 02:26 AM
  5. cant change VIN
    By Samdogmx in forum Vortec V6/V8 Specific
    Last Post: November 12th, 2007, 11:35 PM
