Results 1 to 10 of 11
Thread: How to catch when codes are thrown in logging?
    Apr 2009
    Default How to catch when codes are thrown in logging?
    A buddy of mine is getting intermittent
    P0171 - Fuel Trim System Lean Bank 1
    How would I log for that so we could see what is going on when the code actually hits?
    2001 Corvette Z06
    That's hard...
    For some DTC's you can see the PCM manipulate some parameters (for example for P0420 you can see the commanded AFR do some strange transitions after you coast down to a stop from a freeway run)...
    You would need knowledge of what conditions trigger the test to run, and what conditions cause it to fail, and then look for these in a log... the GM serviced manual lists the test trigger conditions and the test fail conditions in detail.
    Dec 2007
    Also you could read the "freeze frame" data out. This is a snapshot of what is happening when the DTC is posted. i.e. speed, map, pedal, rpm, phase of the moon, etc etc. Many items.
    Usually for Fuel Trims to post lean it means that the LTFT is hitting max rich and still not getting the mixture into stoich.
    Mostly GM seems to set max rich to 1.25 or 25% rich. To post the DTC means that it wants 30 or 35 for example. You get the picture.
    Feb 2006
    It would help if you could view the freeze frame or failure record data. This data is a PCM saved single frame snapshot of the condition when it happened. You could then tell if only one bank was way out of range or the other was imminent of setting a lean code as well. If it appeared as if both banks were very lean, look for something that is shared. This would be fuel pressure, fuel quality, MAF, MAP, etc. If only one bank is lean and the other is OK, check for bank only problems. This could be a leaking intake/exhaust manifold or gasket, O2, or misfire on that side.
    Al
    Ken,
    Those two are ahead of me......Freeze Frame data is saved whenever a DTC sets.
    Apr 2009
    How do you read out that freeze frame data?
    Probably should do some logs on his car and watch the LT Fuel Trims. If they are both frequently putting out over 15, then it could be tune or could be some mechanical fuel shortage. If it's isolated to one bank, most likely a leak or bad injector.
    From scantool, connect to vehicle, then go Info->History Freeze Frame Data.
    Each FF says which DTC it was for.
    Dec 2007
    And here is a FF snapshot (maybe it was the CAT TEMP being 76,000 deg C that popped the DTC?):
    [DTCS]
    P0106=ECM,-F--X--S
    P0107=ECM,-F--X--S
    P0315=ECM,-FPHXNCS
    [ECM Freeze Frame 0]
    DTCFRZF=P0107
    ODOFIRST=40km
    ODOLAST=40km
    FFCOUNT=0Count
    FFPASS=0Count
    FFNOTRUN=0Count
    FUELSYS1=OL-Drive
    FUELSYS2=OL-Drive
    LOAD_PCT=8.2%
    ECT=89°C
    SHRTFT1=0.0%
    LONGFT1=-6.3%
    SHRTFT2=0.0%
    LONGFT2=-5.5%
    FRP=399.0kPa
    MAP=10kPa
    RPM=2022rpm
    VSS=79kmh
    SPARKADV=-0.5°
    IAT=26°C
    MAF=7.6g/s
    TP=16.5%
    AIR_STAT=OFF
    O2S11V=0.000V
    SHRTFT11=0.0%
    O2S12V=0.445V
    SHRTFT12=99.2%
    O2S21V=0.000V
    SHRTFT21=0.0%
    O2S22V=0.450V
    SHRTFT22=99.2%
    PTO=Off
    RUNTM=150s
    EGR_PCT=0.0%
    EGR_ERR=0.0%
    EVAP_PCT=0.0%
    FLI=0.0%
    WARM_UPS=1Count
    CLR_DIST=41km
    EVAP_VP=0.0Pa
    BARO=98kPa
    CATEMP11=76460.0°C
    CATEMP21=79260.0°C
    VPWR=13.073V
    LOAD_ABS=5.5%
    EQ_RAT=1.000EQR
    TP_R=3.9%
    AAT=23°C
    TP_B=16.5%
    APP_D=18.8%
    APP_E=8.6%
    TAC_PCT=5.5%
    E85R=0.0%
    ACC=Off
    ACCWOTD=Enabled
    ACCPRSD=Disabled
    ACREQ=Off
    ACHSPS=Inactive
    ACLSPS=Inactive
    ACREC=Off
    BPIT=Off
    BPITF=Off
    BPMT=Off
    BPMTF=Off
    BPA=Active
    BPSW=Active
    EBPSW=Inactive
    REVINH=Inactive
    REVSW=Off
    UPSHIFT=Off
    SSLAMP=Off
    SSSOL=Off
    CPTOP=OK
    CPBOT=Failed
    EOLVL=Low
    EOLVLF=Low
    EOLVLI=Off
    EOPRS=Low
    EOPRSF=Low
    EOPRSI=Off
    EOCHGI=On
    CANVENT=Open
    COLDST=No
    FVL=Low
    FWDLOW=Inactive
    FWDLOWF=OK
    FWDMODE=Inactive
    RAXLOW=Inactive
    CKREQ=Inactive
    ACCES=Inactive
    PTRLY=On
    STRLY=Off
    REMST=No
    PTOREM=No
    ATPN=Inactive
    FTLE=Disabled
    FCLA=Closed
    PEA=Inactive
    HCEA=Inactive
    DFCOA=Active
    FPO=On
    SFPO=Off
    CPA=Inactive
    PTOFI=Inactive
    FISW=Inactive
    FISWS=OK
    PTOESW=Inactive
    PTOSW1=Inactive
    PTOSW2=Inactive
    PTOSWS=OK
    PTOREM=No
    EGR=0.0%
    ECT1ST=93°C
    FPUMPDC=100.0%
    FTC=15Cell
    IDLERPM=648rpm
    $1297=$FD01
    ETCPED=0.0%
    ETCTP=5.4%
    INJPWB1=1.0ms
    INJPWB2=1.0ms
    KNKRET=0.0°
    TPDES=5.5%
    APP=0.0%
    FUELREM=0.0l
    AIVON=No
    AIVSHG=Failed
    AIVOP=Failed
    AIVSHV=Indeterm
    AIPON=No
    AIPSHG=Failed
    AIPOP=Failed
    AIPSHV=Indeterm
    VSSON=Yes
    VSSSHG=Passed
    VSSOP=Indeterm
    VSSSHV=Passed
    OFFTIME=20s
    VHSON=Yes
    VHSSHG=Indeterm
    VHSOP=Indeterm
    VHSSHV=Indeterm
    RPMCAM=2023rpm
    RPMCKP=2021rpm
    O2H11ON=Yes
    O2H11SHG=Passed
    O2H11OP=Passed
    O2H11SHV=Passed
    O2H12ON=Yes
    O2H12SHG=Failed
    O2H12OP=Failed
    O2H12SHV=Indeterm
    O2H21ON=Yes
    O2H21SHG=Passed
    O2H21OP=Passed
    O2H21SHV=Passed
    O2H22ON=Yes
    O2H22SHG=Failed
    O2H22OP=Failed
    O2H22SHV=Indeterm
    ENGOILP=268kPa
    VREFA=233Count
    VREFB=233Count
    PTRVOLT=13.1V
    CCSW=OK
    CCACTIVE=No
    CCCANCEL=Inactive
    CCDEC=Inactive
    CCINC=Inactive
    CCRES=Inactive
    CCSET=Inactive
    CCONSW=Inactive
    AFMAON=No
    AFMASHG=Failed
    AFMAOP=Failed
    AFMASHV=Failed
    AFMBON=No
    AFMBSHG=Failed
    AFMBOP=Failed
    AFMBSHV=Failed
    AFMCON=No
    AFMCSHG=Failed
    AFMCOP=Failed
    AFMCSHV=Failed
    AFMDON=No
    AFMDSHG=Failed
    AFMDOP=Failed
    AFMDSHV=Failed
    EOT=-40°C
    $1559=$00
    $155A=$C0
    $157A=$0000
    EXPHAB1=0.0°
    INPHAB1=0.0°
    EXPHAB2=0.0°
    INPHAB2=0.0°
    EXPHDB1=0.0°
    INPHDB1=0.0°
    EXPHDB2=0.0°
    INPHDB2=0.0°
    TFT=0°C
    TOS=0rpm
    TCRATIO=1.00:1
    $1A2D=$FF00
    $2002=$0A
    $2005=$45
    IAT2=0°C
    IMTVDC=0.0%
    SCBDC=0.0%
    $200E=$0000
    $200F=$0000
    $201F=$00
    $2027=$00
    $2029=$00
    $2050=$0000
    ACCEP=0.0%
    $2822=$00
    GENFDC=18.8%
    DESTQ=0.0%
    TRACTRQ=0.0%
    TTQRET=0.0°
    ETCTPS2=0.824V
    ETCTPS1=4.157V
    ETCPPS2=0.431V
    ETCPPS1=0.941V
    MAFFREQ2=3037Hz
    TRQDES=0.00Nm
    TRQTRANS=64.96Nm
    TPMIN1=0.608V
    TPMIN2=0.608V
    TADC=22.4%
    GENLDC=100.0%
    $2000=$06
    $2003=$00
    $2007=$00
    $200C=$3F
    $200D=$3F
    $2028=$00
    Jan 2006
    What are we tweaking on?
    Maybe of some help here:
    http://service.gm.com/gmspo/mode6/index.html
    John
    Quote Originally Posted by gmh308 View Post
    [DTCS]
    P0106=ECM,-F--X--S
    P0107=ECM,-F--X--S
    P0315=ECM,-FPHXNCS
    DTCFRZF=P0107
    MAP=10kPa
    RPM=2022rpm
    VSS=79kmh
    SPARKADV=-0.5°
    IAT=26°C
    MAF=7.6g/s
    TP=16.5%
    lol, that's a misinterpretation of that field...
    the DTC is P0107...
    MAP=10kPa is too low noting that throttle is not closed TP=16.5%
    See: http://www.ls2.com/boggs/dtcs/DTC%20P0107.htm
    Oh, I see you found how to read DTC's from V2 itself...
  1. Idling at -5 degrees timing=$ thrown away
    By killerbee in forum Duramax LLY
    Last Post: August 12th, 2009, 02:58 PM
  2. E38 & Codes
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: March 31st, 2009, 04:07 AM
  3. Code P0481 & P0315 Being Thrown Can't Find it in EFI
    By MN C5 in forum E37, E38 & E67 PFI ECM's
    Last Post: October 13th, 2008, 09:22 AM
  4. Dash error codes while logging
    By alian in forum Black Box Logging
    Last Post: August 18th, 2008, 07:27 PM
  5. PCV Catch Cans for Sale
    By TAQuickness in forum Lounge
    Last Post: April 11th, 2008, 01:52 AM
