Results 1 to 7 of 7
Thread: Ls1 pcm running electronic throttle
    Mar 2009
    Default Ls1 pcm running electronic throttle
    can i run the l98 or l76 E38 pcm electronic throtle system off an ls1 pcm. i wouldnt think is was possible but may as well ask.
    Senior Member doubledip's Avatar
    May 2008
    yes but not a straight forward swap...
    1 way (the Aussie way) is if you have a LS1 PCM froma VZ Model (2005) has blue and green plugs... then you will also need a TAC module... and then also a FBW convertor box as the hitachi TB's are different to the 6L...
    the other way is the US corvette 2002 Z06 i think it is way.. they run the LS1 411 PCM but not sure exactly on the other details.. there would be others on here who could answer the question better for that.
    E38's got to love them
    E40's hate 'em
    LS1's is there anything it wont work on
    Holden VE SSV - GEN46L
    www.ultimateconversionwiring.com.au
    www.dualflash.com.au
    Mar 2009
    so its gonna be easier and cheaper to get a cable throttle probably.
    May 2008
    for sure... by the time you buy a Throttle Pedal, TAC Module and convertor box you will already be over the price of the Cable throttle body... but then the other problem/price you need to factor in ... (only guessing you have done a conversion form 5.7 cable LS1 to 6.0L FBW) need to swap injector plugs, map extension, knock extension, knock sensors and relocation, IAC motor and tps for cable throttle body, reluctor and cam gear change or 58x to 24x convertor module...
    E40's hate 'em
    Mar 2009
    yes. all that other stuff is the same tho reluctor wheel etc. if i go cable or not. i'm thinking of doing a l98 conversion.
    May 2008
    no worries... is it into a commodore or something like that
    we supply those parts all the time.. conversion kits
    if it is a car with the LS1 already in it then stick with the cable throttle body setup...much easier
    E40's hate 'em
    Jul 2003
    E38s can't control IAC.
    Might as well talk to mike@eficonnection.
  1. Tuning trans with Electronic Throttle
    By samh_08 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 21st, 2009, 12:56 AM
  2. How to get a 4.8 off the line if it has an electronic throttle
    By chevyman08 in forum Gen III V8 Specific
    Last Post: July 25th, 2008, 11:40 AM
  3. Electronic throttle control
    By VHR in forum E37, E38 & E67 PFI ECM's
    Last Post: April 21st, 2008, 02:49 PM
  4. Electronic Throttle Tables for LS2s?
    By Acer in forum Gen IV V8 Specific
    Last Post: June 21st, 2007, 06:04 PM
  5. Electronic Throttle Control Error
    By racer383 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 27th, 2006, 01:00 AM
