Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: I paid for EFLIve, why can't I flash COS3?
    Lifetime Member Mr. P.'s Avatar
    May 2007
    Default I paid for EFLIve, why can't I flash COS3?
    Hi - I purchased the commercial version of EFILive Flashscan V2 several years ago from Justin Gadberry (Black Bear Performance) and last night attempted to flash Custom Operating System 3 to my PCM and received a dialog box stating that this feature was only available to users with Custom or Workshop versions of the software ??? Apparently there is a licensing issue with the software, will someone please tell me how to address this so I can use the features I paid for? It would be much appreciated - Thanks.
    Mr. P.
    PS - forgot to add, I am running build 7.5.5.88
    Lifetime Member Doc's Avatar
    Oct 2005
    That's really odd. Can you post a screen shot? All the COS's are free AFAIK.
    www.efialchemy.com
    www.greatamericancarwar.com
    Oct 2004
    I trust you are connecting the FlashScan device to you PC prior to opening the Tune Tool? If not irrespective of your paid license level, the software will run in effective Personal Mode.
    Check the FlashScan license level by:
    - Connecting the interface to your PC
    - Open the Tune Tool
    - Select the 'Help->FlashScan V2 VIN Licensing' menu option
    Andrew
    EFILive Crew
    May 2007
    I already figured that - I re-plugged & restarted, I was able to do a full PCM read & save, and then opened/loaded COS3, typed in my VIN and tried to flash and got the dialog window. And I also immediately re-loaded the PCM backup, made a minor change and was able to push the changes to the PCM... but still do not have the option to upload COS3. The issue is not a USB communication issue (that I can tell).
    HELP!
    Mr. P.
    Do this:
    - connect V2 to PC,
    - open tunetool,
    - go Help->About,
    - post a screenshot of the resulting screen.
    May 2007
    Nov 2006
    Joecar, Is there anything special in that new version you got?
    LC-1 WBO2
    It just the September 7th BBR beta test update...
    it's for reading BBR files from V2 and comparing against the original tun file...
    it has some other fixes/features, Paul will make ths available soon...
    we have been testing it to make sure it's working right.
    Dont let the regular people see the RC stuff, NOOOOOO!!!! Hahaha jk.
    Run the update program for V7.5, cant remember what the latest public version is these days.
    Plug your V2 in and tell us what Help->Register EFILive says. Should say Commercial Scan & Tune, basically make sure those details are EXACTLY what your blue card that came with your hardware says.
    May 2007
    The blue registration card does say Commercial Scan & Tune (ser no 003615881589 if anyone from EFILive is monitoring this thread).
    OK so what I am getting here is -
    1. I have the right software
    2. I have the right license
    3. It refuses to work
    4. Nobody on the forum has run into this before, apparently
    I have Justin and Jenna's number at home, I'll just ring them tomorrow. I was hoping that I would find a past experience here to help, or maybe one of the developers chime in with some support.
    Mr. P.
  1. Help with cos3
    By EVODRIFTER in forum Custom Operating Systems
    Last Post: November 2nd, 2008, 03:50 PM
  2. IS COS3 for SD only?
    By WeathermanShawn in forum General (Petrol, Gas, Ethanol)
    Last Post: September 30th, 2008, 01:48 PM
  3. Real Time Monitoring freezes EFLive & Dashboard Not working
    By gmh308 in forum Gen IV V8 Specific
    Last Post: September 25th, 2008, 10:47 AM
  4. Few questions after COS3 flash
    By white01ss in forum Custom Operating Systems
    Last Post: August 15th, 2008, 11:50 AM
  5. V2 Cos3
    By Chevy366 in forum FlashScan V2
    Last Post: April 20th, 2007, 10:12 AM
