Results 1 to 4 of 4
Thread: rpm threshold
    Sep 2005
    Default rpm threshold
    i changed my in gear thresholds to 6850 upper and 6775 lower. should i change the in p/n threshold to the same? i also have the fuel cut-off set at 6800 in gear but left the p/n cutoff at 6500. should i change those to the in gear settings also?
    2002 NBM SS - 335 hp package, chrome 10-spokes, lid, cam, qtp lt\'s and ory
    Jan 2004
    I would change them just for the fact if you decided to launch hard at 6800 rpms. LOL Actually in a M6 the in gear is all that is used. P/N I believe is only referenced for Autos.
    Quote Originally Posted by black02ss
    Some tables (not all) use the P/N values when the clutch is pressed.
    Sep 2005
    8) i'll change them before i flash the pcm
  1. RPM Threshold for Airflow Calc {B0120}:
    By Mark300 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 2nd, 2009, 01:40 PM
  2. Trouble w/ PE throttle threshold
    By HTMtrSprt in forum E37, E38 & E67 PFI ECM's
    Last Post: October 7th, 2008, 04:21 PM
  3. Base Spark Threshold cells?
    By ArKay99 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 2nd, 2008, 12:47 PM
  4. Replies: 12
    Last Post: December 13th, 2007, 11:52 AM
