Results 1 to 10 of 14
Thread: PCM Bench Harness Wiring diagrams
    Default PCM Bench Harness Wiring diagrams
    New EFILive document showing how to wire bench harnesses for 1999+ and 1998 PCMs is now available here:
    http://www.efilive.com/doc/Tutorials...20Tutorial.pdf
    Lifetime Member SS2win's Avatar
    Feb 2005
    so thats all it takes to program on the bench? cool.
    2001 Camaro SS
    EFILive Custom OS3
    Jan 2005
    sweet! now I can blow stuff up on my bench!
    No, that's my job, though I must admit, I haven't smoked one yet.
    Sep 2005
    OK, now for the $100 question, where can I find plugs for the pcm and obd2 port to make a bench harness?
    Member bK's Avatar
    Mar 2004
    Can you have a harness connector directly wired into a db9? This would bypass the OBDII connector all together.
    Lifetime Member mistermike's Avatar
    Dec 2003
    Quote Originally Posted by GMPX
    I tried to, but it's too big for my bong.
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    Quote Originally Posted by bK
    Yes - good idea, I will add that into the diagram.
    Yes, where can we purchase the pcm connectors from...?
    No idea, all of ours come from old wiring looms.
  1. Bench Harness?
    By GAMEOVER in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 31st, 2009, 11:33 AM
  2. bench harness for ls2 and e38
    Last Post: March 29th, 2007, 01:39 PM
  3. bench harness
    Last Post: June 15th, 2006, 05:09 AM
  4. Bench Harness
    By Biodiesel66 in forum Duramax LB7
    Last Post: May 3rd, 2006, 09:34 PM
  5. bench harness
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2005, 03:25 AM
