Results 1 to 10 of 19
Thread: Locking converter in 2nd gear...
    May 2008
    Default Locking converter in 2nd gear...
    If you have a really loose converter can you lock the converter in 2nd gear?
    Will it unlock for the shift?
    Being you cannot feel it shift at normal driving would it hurt to have it locked during the 2-3 shift at light throttle?
    Lee
    230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads,
    MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB,
    PowerGlide, 5000 stall converter. 8.70@154 MPH
    My Projects Homepage: http://www.horsepowerracing.com
    May 2008
    Nobody? Someone has to of locked the converter in 2nd!
    There's a table to apply the TCC in 2nd gear, see D1001 (you have to make sure D1004 is below D1001).
    D2801 can be set to allow the TCC to stay applied during an upshift... altho, I'm not sure if this parameter works on all trans calibrations.
    Keeping TCC applied during upshift:
    if engine is making sufficient torque then the TCC damper springs may break (see item (C) in attachment)... or the TCC may slip during the upshift (it is only "half" a clutch and so doesn't "clamp" like a "sandwich" as in a manual trans clutch).
    Typically a double or triple plate TCC will allow slip-free upshifts with TCC applied since the extra friction/steel plate "sandwich" is able to "clamp" tight... 2P/3P clutches don't necessarily have the damper springs.
    Edit: oops, I forgot to attach attachment...
    May 2008
    This is why I was wondering if the loose 4000RPM stall converter could take it. Right now you cannot feel the shift unless your foots in it. Even though the converter is cushioning the shift does the clutch in the converter still take a hard hit? Does that make sense?
    Lee
    Lifetime Member Mr. P.'s Avatar
    May 2007
    What transmission?
    Yes you can tailor converter clutch state in each gear. Separately, you can instruct the tune to also leave the converter locked during shifts.
    Is it hard on the converter clutch? Hell yes. You better have a converter clutch rated for this kind of abuse, like a multiple-disc lockup clutch.
    But the real worry is not the converter but the transmission - the issue is leaving the TCC locked during the shift, it hits SO HARD that with any kind of power you risk destroying the transmission input drum and/or other hard parts.
    Mr. P.
    May 2008
    It's a 4L80E.
    So it would still hit too hard with the high stall...
    But what about just locking it in 2nd and let it release for the shift?
    May 2007
    Quote Originally Posted by LS1_Dragster View Post
    It's a 4L80E.
    When the lockup clutch is engaged there is no "stall" - the front half of the converter is physically locked to the rear-half. If you want to demonstrate this to yourself, take EFILive bidirectional menu, roll-out in 1st gear & lock the TCC, then moderately accellerate to about 20-mph and feel just how hard it hammers into 2nd under lockup Being a lightweight dragster and 80E the car actually *might* get away with shifting while locked-up, I will have to ask our transmission expert what he would do to an 80E to hold up to this but I am thinking with that trans it can be done in your application. I am going to say from certain experience a 4L60 won't take that sh!t for long lol, you will fracture the input drum even if it is 'reinforced' - now if someone were ever to make a billet input drum for the 700/4L60 that would be an entirely different story . For track use you SHOULD be running with the converter in lockup whenever possible. What we do on the trucks, is to make repeated runs lowering the lockup engage MPH until the fastest time/performance is achieved per each gear. Typically (in heavy trucks) we benefit from TCC lockup in 4th, 3rd, and upper part of 2nd, some of the stock trucks loose E.T. attempting to lockup in 2nd (they don't have enough torque to take advantage) so a little trial/error is expected. For street use we keep the TCC lockup point 5+ mph higher than the shift point, but on a track-specific vehicle you might be able to get more ET gain by locking-up the TCC even quicker than that.
    Mr. P.
    May 2008
    It's not for the dragster it's for the firebird. It's a pain sometimes driving because the RPM's are screaming at 2500 and the cars going 5MPH! Hughes just built the converter too loose, I'm sending it back for a re-stall but not until the car is parked for the winter so in the mean time I was looking for a short term solution....
    Senior Member MyM8V8's Avatar
    Aug 2008
    Quote Originally Posted by Mr. P. View Post
    Mr. P.
    So where would we be able to get such an item???
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    May 2007
    Nobody makes an aftermarket drum for the 4L60. :( We are considering lathing one out of 4340 billet, but it will take a ton of time (like a straight week of milling) because the cutting tools have to reach so deep into the drum and still meet extremely close tolerances. We think we can do it, we'll see.
    Mr. P.
  1. converter locking in 2nd & 3rd @ WOT
    By Superado in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 31st, 2009, 08:27 AM
  2. TCC Locking
    By GMPX in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 24th, 2009, 08:22 PM
  3. Locking ecm
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 19th, 2007, 02:10 PM
  4. Locking and unlocking converter in 3rd gear
    By Scott(382-$T$) in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 29th, 2006, 04:25 PM
