Results 1 to 8 of 8
Thread: Attempted a VVE and Disconnecting the MAF Killed the Engine
    Lifetime Member MN C5's Avatar
    Mar 2005
    Default Attempted a VVE and Disconnecting the MAF Killed the Engine
    It would run for about 5 minutes go into reduced power mode, stall and not restart. I ended up reflashing it on the side of the freeway and hooking the MAF back up to get it home. It runs ok with the MAF hooked up but I want to dial in the VVE table.
    I attached my two bar tune if someone is able to tell me where I went off track with the tune.
    You know the IAT sensor is part of the MAF?
    Mar 2005
    Yes, my IAT was relocated as part of the Supercharger install.
    Mar 2005
    Tried again today, no such luck. It puked after about 1.5 miles into reduced power mode. It also threw a MAP P0106 performance code as part of the reduced power mode. I went through the tutorial and think the tune has everything covered "" obviously I must be missing something.
    Random but thinking out loud here, do you have another OS you could full flash and try? Might be worth a shot, and you're an E38 right?
    Mar 2005
    I do have another OS I can flash, its worth a try.
    Mar 2005
    Quote Originally Posted by MN C5 View Post
    Flashed the new OS and everything works fine. Weird, but he11 it runs great now. Removing the MAF from the intake track moved the boost up 2psi from the 18.8 I was running.
    Weird, glad ya tried that though, took a little bit of time on the PC vs ripping the truck apart for no reason!
    For reference, could you post up the OS that didnt work and the OS that did?
  1. scanner keeps disconnecting
    By Ls1joe in forum E37, E38 & E67 PFI ECM's
    Last Post: July 24th, 2009, 05:15 AM
  2. KILLED my NEW reman...
    By onewingman in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 4th, 2008, 06:28 AM
  3. I think I killed another ECM...
    By epb091786 in forum Duramax LB7
    Last Post: December 24th, 2007, 12:30 AM
  4. Killed my pcm
    By Boosted GMC in forum General (Petrol, Gas, Ethanol)
    Last Post: December 17th, 2006, 09:02 AM
