Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: w.b. keeps throwing a code? po1153
    Lifetime Member smslyguy's Avatar
    Oct 2008
    Default w.b. keeps throwing a code? po1153
    my lc1 wideband keeps throwing a code po1153 after about 40-50 miles of driving. I do notice that the gauge also fluctiates while steady cruising from 14.7 to around 14.1 even under light loads. when the mil light comes on then the lc1 gauge reads a pretty steady 14.6 at cruising. Don't know what's goin on with this? I have adjusted the speeds on the lc-1 as well, with no luck. any suggestions??? here is a copy of my log before the mil light.
    2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
    Now own a 2015 1LE camaro
    Nov 2006
    Set P0153 to NO MIL.
    You now have STFT/LTFT data and the NBO2 voltage is not stuck @ .450v.
    What did you do to fix that?
    LC-1 WBO2
    Oct 2008
    [QUOTE=mr.prick;104118]Set P0153 to NO MIL.
    What did you do to fix that?[/QUOTE
    I had it hooked up wrong.So by setting this to no mil doesn't it still go into "limp mode" or not?
    Nov 2006
    You won't get the DTC light.
    LC-1 WBO2
    Oct 2008
    Quote Originally Posted by mr.prick View Post
    did you notice on the log the fluctuation in the afr at cruising speed? Is this normal?
    Nov 2006
    AFR will bounce a little.
    Cut your PIDs down until total channels selected is no more than 24.
    LC-1 WBO2
    Oct 2008
    even without logging data on efi live it still fluctuates on the gauge for the lc-1 as it does on the log i have posted. (I bought the gauge kit for the lc-1)
    Junior Member 01Z's Avatar
    Jan 2008
    I'm getting the P1153 and P0154 with my LM-1 too. Apparently you are simulating your narrow band through the controller because your WB sensor is in the NB bung correct??
    Anyway, I thought my problem was the length and quality of the connection. There isn't enough voltage fluctuation because of resistance. My plan is to shorten and tighten the wiring from the controller analog #1 output to the harness O2 sensor weather-pack. Does this sound like your situation?
    2001 Chevrolet Camaro Z28 - GM LS6 H/C
    EFILive FlashScan V1 - 7.5.6 (Build 133)
    Oct 2008
    Quote Originally Posted by 01Z View Post
    yes i have it simulating one side of my narrow band. Although, i did not get a po154 code. let me know if shorting the wires up helps you out at all.
    Oct 2008
    it was p1153 (insufficeint switching bank2 sensor1) that set the mil light not po153. Should i still set p1153 to no mil?
  1. Tow tune throwing s P0401 and P0101?
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 22nd, 2009, 04:57 AM
  2. egr code?
    By hutch in forum Duramax LLY
    Last Post: October 3rd, 2009, 04:55 AM
  3. Code P062F and Code P0633 Help
    By Airtime in forum General (Diesel)
    Last Post: September 28th, 2009, 01:57 AM
  4. key code
    By beaukz28 in forum Purchase and Shipping
    Last Post: October 14th, 2008, 04:35 PM
  5. Strange throwing codes 1133 & 1153
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 13th, 2007, 08:32 AM
