Results 1 to 7 of 7
Thread: Trouble loading DSP5 Tune
    Sep 2009
    Default Trouble loading DSP5 Tune
    I made a mistake when loading my DSP5 tune as I did not load it using the full flash mode. When driving I could not switch the tunes. Was just set on one tune only. When I went to do the full flash I received an error message and it could not do the reflash. I tried it again without using the High Speed setting and I clicked the Alt Keys button. It then got hung on "retrying previous boot code" for over 40 minutes. I had to stop the process and now when trying to reload the stock configuration it cannot read the ECM. Am I screwed with a bad ECM now???
    Thanks,
    Devin
    Devin, you should be ok to re-try.
    Not sure what the trouble is, but maybe try pulling the battery for 30 seconds and restart the PC.
    Sep 2009
    Well unfortunately I tried this an no luck. Still says the ECM is in an unknown state. It's missing the calibration. Any other ideas?
    EFI Live gave me the warning not to interupt the full flash but what are you supposed to do when it's just hanging on a step for over 40 minutes??? Arrgg.
    Thanks anyone for your advice.
    Devin
    Ok, you will get the warning that it is missing the calibration (as it is), but you should be able to just click past that and the tune will then go in.
    When you tried the full flash, did it get anywhere? Like part way, or didn't even start?
    Sep 2009
    Yes it allows me to get past the warning section but then it rejects the bootlegger strap? portion. It stops there.
    When I tried the full flash the 1st time it got to 9K and hung at the "retrying boot code" portion. That's where I stopped it after 43min.
    I sent my bug files to Paul in hopes he can determine if my ECM is dead. I'm curious if this is the same issue that was posted a few months ago when the new version came out. I had problems with the drivers not being loaded and had to do some work there before I could even get my V2 to communicate with my PC.
    Quote Originally Posted by Dmaxx 02 View Post
    If it only got that far and froze then sorry to say but the ECM is dead. Have you always had trouble programming that truck?
    Sep 2009
    I have done the full flash in the past with a single tune with no problems. It was only this time with the DSP5 tune and me upgrading to the new EFI Live version.
  1. Odd problem with loading a tune
    By Telco in forum Gen IV V8 Specific
    Last Post: November 27th, 2013, 10:24 AM
  2. Trouble loading pid selection to BB
    By Picto in forum Black Box Logging
    Last Post: November 15th, 2010, 05:00 AM
  3. Loading DSP5 for first time
    By kdawg62 in forum Duramax LB7
    Last Post: May 20th, 2010, 01:49 PM
  4. Trouble loading 2002 OS in 1999 PCM
    By Beer99C5 in forum Custom Operating Systems
    Last Post: October 9th, 2007, 05:20 AM
  5. Trouble loading V7.31 after system reinstall.
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: March 5th, 2006, 08:40 AM
