Results 1 to 5 of 5
Thread: Low sulfur diesel fuel
    Sep 2009
    Default Low sulfur diesel fuel
    Hey guys i just did a complete DPF,DOC,& EGR blocker delete turned off all codes regarding DPF,DOC & EGR I even gave the truck a lopy idle which sounds great my question is can i run LSD fuel in my engine? I have a 2008 LMM 3500 hd the reason i asked is because LSD fuel has more sulfur or lubricate in it which is better for the injectors & injection pump
    Like the 10-15ppm ultra low sulfur diesel thats available everywhere? Your truck is designed to run on ULSD especially with a DPF (even though thats removed now)...here in WA and ID I havent seen anything but ULSD since 2007 when the mandated implementation began.
    So yes, you will be fine.
    Lifetime Member Cougar281's Avatar
    Jan 2006
    The only reason the truck was "designed" for ULSD is that stupid POS DPF. With it gone, you can run whatever you want in it. The ULSD is JUNK. I run LSD every time I see it (and I actually have seen it at a few truck stops). I'd even run "high" sulfer fuel if I could find it. The higher the sulfer content, the better the fuel will lubricate things like the CP3 that need that lubrication to survive.
    Jan 2008
    Quote Originally Posted by Cougar281 View Post
    #2 home heating oil here. same as LSD. ULSD is terrible for the engines.
    I figured it was designed for ULSD to deal with the DPF, didnt know you could run whatever after its in the trash. Good to know, Im not a big diesel guy although I envisioned a 4.5L Dmax swap into a mid-70s C10 pickup...bummer its not being produced.
  1. Loping Diesel
    By 1Badmax in forum Duramax LLY
    Last Post: October 21st, 2010, 01:19 PM
  2. first diesel tune
    By pullincrazy88 in forum Duramax LB7
    Last Post: March 26th, 2010, 01:21 PM
  3. jump from gas to diesel....
    By 0rion in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 7th, 2010, 05:23 AM
  4. air to fuel on diesel
    By ZL1Killa in forum General (Diesel)
    Last Post: September 14th, 2007, 04:26 AM
