Results 1 to 8 of 8
Thread: Version 7.3
    Sep 2005
    Default Version 7.3
    Im having trouble installing version 7. I erased the old files and unzipped the new files into the existing directory. This is not working . SOS!!!!!
    2002 GMC Sierra ECSB
    Turbonetics T7675 6lbs boost, 42lb injectors, Single 4 inch exhaust with Hi-Flow Cats, 6.0 swap, Comp Cam LS9 Cam, EFIlive Tune, E-fans, Snow Performance Meth Kit, soon to add KB Boost a Pump,
    Sep 2005
    i had the same problem. black02ss helped me out and got me fixed up.
    2002 NBM SS - 335 hp package, chrome 10-spokes, lid, cam, qtp lt\'s and ory
    Default Re: Version 7.3
    Quote Originally Posted by jamesbond2509
    Don't erase any files from the existing EFILive V7.2.x installation. The V7.3 update only includes the files that have changed.
    If you have uninstalled V7.2.x or deleted any V7.2.x files, then please re-run the V7.2.x intallation from the installation CD and select the [Repair] option. Then perform the V7.3 update as per these instructions (without deleting or unistalling anything first).
    http://www.efilive.com/downloads/downloads_730.html
    P.S. I have now changed the V7.3 installation instructions to inlcude that warning.
    Jan 2004
    Paul,
    It appeared that in NviouSS's situtation that Norton Anti-Virus was changing the gm_enhanced.prn file. We had to manually exit Norton and make sure it wasn't runing. After that it installed flawlessly.
    Quote Originally Posted by black02ss
    Paul,
    That's annoying. I guess Norton is getting a false positive on that file as a virus. I can assure everyone that gm)enhanced.prn is not a virus and does not carry any viral code. It has been checked with NOD32.
    In other news, I highly recommend NOD32 (www.eset.com) for virus software, it is by far the best virus software I have ever used - and I have used most of the "big" names.
    It is easy to configure, extrememly fast, accurate (never failed), and very unobtrusive and has never caused me a single problem on any of our PCs.
    It is network enabled so that the server is updated from Eset and all the other PCs on the network are updated from the server. It is usually updated once per day sometimes more often.
    I highly recommend using it. I would not go back to Norton, McAfee or any of the other "popular" AV packages after using NOD32.
    Sep 2005
    Default One more question on V7.3
    i've reinstalled the previous version and now i am about to download V7.3. can I extract all the files onto c:/program files/efilive/v7. I noticed the software created some directories in "my documents" as well. What is the best way to do this. Earlier in the day parts of the software existed in both locations and the scanner dashboard was not work.
    please advise
    Sep 2005
    dbl click the pre-release folder to open it
    hilight everything EXTEPT USER CONFIGURAION
    right click - copy
    open programs/efi live/v7
    right click, paste
    click yes to all to overwrite existing files
    go back to the pre-relese folder
    right click user configuration
    open my documents/efilive/v7
    right click anywhere in folder, paste
    click yes to overwrite
    (download the efilive_stock_cal_20051004 if you haven't already)
    open the stock cal folder
    highlight all files, right click, copy
    right click anywhere, paste
    once you get that done, v7.3 should be running. hope that helps.
    Sep 2005
    Its up and running thanks for your quick response!
  1. Version 7.4 won't go away
    By 01Z in forum FlashScan V1
    Last Post: October 3rd, 2009, 10:20 AM
  2. LS1 version 2
    By ws6togo in forum Lounge
    Last Post: April 19th, 2006, 05:31 AM
  3. Anyone used Version 7.3 yet?
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 15th, 2005, 01:36 PM
