Results 1 to 10 of 12
Thread: Uploaded Tune But Nothin Changed
    Sep 2008
    Default Uploaded Tune But Nothin Changed
    Heres the problem...I just got EFI a couple days ago and today took my stock ECM off and saved it. Opened the modified tune file and hit the red arrow. I had to do the ECM liscening and that, and kept going. Turned the truck off for 15sec then started it. Truck still has the stock ECM. So to make sure I re-downloaded the ECM and its still the stock one. So whats the problem? I've opened the modified file and tried to upload it 3 times now and no luck. Here is a display picture of when I finish "uploading" the modified tune. Thanks guys.
    That has flashed the tune in. How are you determining that it hasn't?
    Sep 2008
    I think I just picked up that maybe it is. I got a tune that has my vanes adjusted to make that cool whistle sound at idle...I don't hear it, sounds stock. But when I download the ECM now, and goto my vane position tables, I see that they arn't the stock settings, in the min to high alt settings from mm3-5 to mm3-15, 120rpm to 800 rpm are set to 10, compared to the stock 85.
    Sep 2008
    Another question...I see there is a boost guage for the LBZ but when I open it so I can use it with the scan tool, there is a line though it. I searched the internet and a fourm said that you had to create the PID for it? "{GM.BOOST2_DMA.psi}-{SAE.BARO.psi}" If that makes sence...I tried to trouble shoot it with the help pdf files in EFI Live but no idea how to do it.
    Quote Originally Posted by Caper01 View Post
    Post your calc_pids.txt file here, someone will edit it for you...
    (located under My Documents\EFILive\V7.5\User Configuration)
    And welcome to the forum...
    Sep 2008
    Heres the file, and thank you. I thought I was pretty computer smart but this EFI Live seems to be more of a handful than I expected....guess with time I should be able to learn it well. Thanks for the help.
    What do you want that pid to be called...?
    Sep 2008
    Whatever....Trubo boost?
    How bout Manifold Boost, would that be ok...?
    Copy attached file back to My Documents\EFILive\V7.5\User Configuration overwrite the original.
    Then start the scantool, goto PIDs tab, click on "Parameter" column to sort alphabetically on that column, look for CALC.BOOST.
    Sep 2008
    Did you have to type that out to get that? Thanks. Try it out later tonight.
  1. Changed to LS2 90mm on LS6
    By Rusty in forum Gen III V8 Specific
    Last Post: April 12th, 2009, 01:57 PM
  2. What can be changed in the TCM?
    By THEFERMANATOR in forum Allison 5 & 6 Speed
    Last Post: March 24th, 2009, 03:38 PM
  3. Changed my IFR...AFR Is erratic
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 8th, 2007, 05:19 AM
  4. Have question about installing new update it changed my tune
    By 02pewterls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 10th, 2005, 10:07 PM
