Results 1 to 8 of 8
Thread: LMM ECM replacement questions
    Default LMM ECM replacement questions
    I ordered a ecm through the ECM outlet pre programmed per vin#. I found that the truck started right off after putting it in without relearning the VATS or anything I thought that was weird. The only thing I had to do was programm injector flow rates and set ign cycles in the pcm security tab to 1 thats it and everything worked fine. I wonder why I did not have to relearn the VATS? When I tried to do it in the pcm secrity tab I got a error 012 or something not sure if thats that exact error code. Any body else have to go through a VATS relearn on a LMM?
    Robert
    04 LB7
    2010 LMM
    2015 LML
    Feb 2007
    I don't think I did anything different from you. I had it programmed with the VIN and correct OS and all was good. The only thing I remember doing was ignition cycles and flow rates like you.
    Thanks, I think VATS only has to be relearned if the ecm is used and ign cycles are at 0 on the used ecm
    04 LB7
    2010 LMM
    2015 LML
    EFILive Distributor Trippin's Avatar
    May 2004
    EFILive can not initiate a "VATS Relearn" for LMM.
    You need to be connected to GM's data base.
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    Quote Originally Posted by Trippin View Post
    I did not know that, well I guess it's a good thing I got a new one dealer visits suck. What about LBZ ecm can we do it on those?
    04 LB7
    2010 LMM
    2015 LML
    Because they are brand new ECM's that have no prior VATS codes stored, try it on a ECM pulled from another truck, it doesn't work.
    Guy, I think I knew that! I'll look in to it and see if I can get TechII to relearn the VATS on the bench.
    I have a feeling it's a case of a certain manufacturer not following the GM spec on VATS relearn. It's the exact same procedure on all Delphi controllers.
    May 2004
    As far as I know even the Tech 2 can't initiate a VAT relearn on the Bosch LBZ/LMM ECMs without being hooked to the internet and GMs data base.
    It returns the following error message:
    "Ich bin nicht sprechen deutsch."
    www.socaldiesel.com
  1. LMM DSP questions / Power questions
    By Djreversal in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 18th, 2011, 07:06 AM
  2. a/c questions?
    By whackem04 in forum Gen III V8 Specific
    Last Post: October 9th, 2009, 02:07 PM
  3. Replies: 26
    Last Post: May 29th, 2008, 06:25 AM
  4. Injector replacement
    By sierra1500 in forum Gen III V8 Specific
    Last Post: April 15th, 2008, 02:59 PM
  5. Help with new LS2 403 replacement in C5
    By ArKay99 in forum Gen III V8 Specific
    Last Post: January 28th, 2008, 02:56 AM
