are the factory pre cat 02 and post cat o2 sensors the same? Can you intermix them?
2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
Now own a 2015 1LE camaro
I think the two pre-cats and the driver's side post-cat are the same on the 98-02 fbodies. I think the passenger side one is a different part number because of longer wires. It's been a while since I've checked into this...so hopefully, someone can back me up.
I am told GM now uses the one part for all four O2 sensors for the 4th gen F-car.
