Can you throw a 2-bar sensor in, change the scaler/offset, and stick with the regular tune? I'm not out of MAF technically and would like to keep it. But, I would also like to get an accurate MAP reading instead of a flat 104kPa. Will the PCM freakout if I do this? If I have to run a custom OS, can I keep the MAF. It's been a while since I read up on the custom OS's.
