Results 1 to 10 of 13
Thread: BBL killing widebands??????
    Senior Member Wasted Income's Avatar
    Dec 2005
    Default BBL killing widebands??????
    I am at my wit's end. I thought the problem was a junk product from Innovate. I am on my 4th LC1 cable...the previous 3 have died randomly.
    Decided to move up to an LM1, worked great for a couple days until the instant that I tried black box logging with the LM1 hooked up via serial. BAM, LM1 is toast. Thinking back, the others may well have also died as soon as I tried BBL with them...I just never added it up until now.
    What is the deal?? How come I keep smoking wideband controllers with V2 BBL????????
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
    I would first like to hear from Innovate what has failed in your wide bands, it's only a serial connection, I'm not sure how anything can be damaged doing what you are doing.
    Dec 2005
    I do not know if they keep records of past repairs. They have just sent me a brand new LC-1 back each time....however, when i send the LM1 back for repair (assuming they repair it...since they don't make them anymore!?) I will ask what the problem is?
    Nov 2006
    There was a firmware a while back that had problems with serial connection
    and AD inputs but that was fixed quickly.
    FW and BB are up to date right?
    LC-1 WBO2
    Lifetime Member mistermike's Avatar
    Dec 2003
    Default Hmmmmm.....
    I am no longer able to connect to the LC-1's with the Innovate software. Neither the LM programmer nor LogWorks can see the LC-1's on a setup that used to work fine. I can connect with the V2 RS232 just fine, and can read jibberish from the serial connection using Hyperterminal. I'm not ready to say that some odd interaction with V2 and LC-1 is responsible, as that is out of my range of knowledge. I just find it odd that a setup that used to work, no longer does.
    Hey Paul, can I Telnet into these friggin things?
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    Dec 2007
    Is this related to:
    http://forum.efilive.com/showpost.ph...76&postcount=7
    (Shield your eyes )
    Wasted Income,
    mistermike,
    What FlashScan V2 firmware version are you running...?
    Quote Originally Posted by gmh308 View Post
    Is this related to:
    (Shield your eyes )
    I don't think he quite expressed clear enough how he felt
    Dec 2003
    Wasted Income,
    mistermike,
    I'm running 2.06.12 firmware and 2.06.02 bootblock
    Dec 2003
    People need to quit sugarcoating it.
    Hey Ross, in all seriousness, it appears that the only thing that can't see my LC-1's is the Innovate application(s) My expertise in datacom protocols is as near zero as you can get. Judging from other peoples experiences with them, I can probably rate the chances of Innovate fixing the problem as approximately the same level as me writing a new API for the damn thing. It's really starting to look like an issue with their software. Klaus appears to be a good engineer, but like many engineers, their assessment of their own programming skills is frequently optimistic.
    All I want to do is to be able to reprogram the @#!** things. There HAS to be some way of talking to these buggers without their Windows app.
  1. EFI Connection...you're killing me!
    By DURAtotheMAX in forum Conversions / Aftermarket Parts
    Last Post: February 4th, 2010, 03:31 AM
  2. RTACS with dual widebands?
    By mistermike in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 14th, 2009, 10:30 AM
  3. Killing Defuel?
    By Cougar281 in forum General (Diesel)
    Last Post: October 25th, 2007, 07:05 AM
  4. Links to widebands that will work with Flashscan/EFIL please
    By DebianDog in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2004, 04:22 PM
