Thread: Wideband support?
    Jul 2009
    Default Wideband support?
    How do you get wideband o2 support with efilive 4? is it possible?
    I want the Wideband O2 recored against TPS, RPM etc....
    How do I do this?
    Thanks.
    Oct 2004
    It is not possible to integrate a wideband O2 controller with EFILive V4 sorry.
    Andrew
    EFILive Crew
    Jul 2009
    is it possible to integrate it with a newer version?
    Im not programming any OBDII stuff, Its just the old GM memcal ECUs so theres no point in me buying the flashscan products, or is there?
    Default Borrow the A/C pressure sensor connector...
    From looking at some older service manuals, it seem that GM has used 0-5V A/C pressure sensors... you should be able to borrow the A/C pressure sensor connector and wire in your wideband 0-5V signal (the mating connector should still be available from somewhere).
    The latest FlashScan V2 device has an ALDL-USB interface built in. We are planning on adding ALDL capability to our V8 Scan Tool software. That means you'll get wide band integration as part of the FlashScan V2 device.
    We don't have an availability date for the ALDL interface update but it probably won't be until 2010.
  1. L76 support
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: October 27th, 2006, 05:10 AM
  2. ls2 support
    By QUICKSILVER2002 in forum General
    Last Post: January 13th, 2006, 05:07 PM
  3. C6 Support ETA
    By SBTuner in forum General (Petrol, Gas, Ethanol)
    Last Post: August 11th, 2005, 01:39 PM
  4. CAN support?
    Last Post: April 27th, 2005, 11:22 AM
