You have more balls then me! I would never ever flog a supercharged vehicle without having a safe tune in place first and even then I would make short low RPM runs, correct the problems then take it to the next step and keep doing that until it's right. I think the water injection is saving your butt.
On the last log you hit 14.31 AFR under boost, I'm not sure why your engine is still running.
I'm coming across harshly but honestly, I wouldn't even run the car NA until the tune was safe. Pull the belt and get it tuned NA first then put the belt back on and tune it slowly under boost. Get a 2 bar MAP sensor and setup the fuel and timing MAP's correctly or say good bye to your engine.....
