Results 1 to 3 of 3
Thread: PN / Gear selection
    Jul 2003
    Default PN / Gear selection
    Hello guys,
    I am having problems with my idle and today i found out the problem. It looks like my PCM is not recognizing that my transmission is in park neutral and therefore only utilizes the in gear tables for idle airflow.
    I did a scanning and when i am in neutral my pcm sees 1st gear... All other gears are commanded fine... This is an A/T.
    That problem "may" be related to another issue i am having. I am not being able to make the tansmission shift according to my VSS tables. I made a change and it took effect and its not taking effect anymore. but... i will be doing some more testing on that.
    Any info or thoughts are appreciated.
    Jul 2005
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
    Jul 2003
    well.. i am not getting that code... i do get the gear the trans is in if its first second.. third.. but not park neutral ....
  1. manual gear selection overide 4l80e
    By 2500ak in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 6th, 2010, 04:48 PM
  2. lm-1 pid selection wants lc-1
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2008, 12:11 PM
  3. pid selection
    By Dale in forum Vortec V6/V8 Specific
    Last Post: November 21st, 2007, 02:55 PM
  4. PID Selection
    By Whodunnit in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: August 22nd, 2007, 07:34 AM
  5. PN / Gear selection
    By Highlander in forum General
    Last Post: October 16th, 2005, 07:58 PM
