Results 1 to 2 of 2
Thread: High RPM power loss solved
    Senior Member PSWired's Avatar
    Jan 2005
    Default High RPM power loss solved
    I was having problems with power loss over 4800 or so RPM in my cammed LQ9 engine. It felt like the engine was being starved for air at those speeds. Since I have a pretty free flowing exhaust (dual 3" to a single 3.5" behind the muffler), decent heads, and an aftermarket cam, I figured the only problem could be the tiny air filter that I have on the engine right now. Well today I decided to do some logs of timing because I felt timing being pulled under heavy acceleration. I saw a lot of spark retard due to engine torque management. Long story short, I disabled the axle torque limiting features and viola! I'm now spinning up to 6K RPM and it just wants to keep going. Now the only type of torque limiting I should have in place is the transmission upshift/downshift torque reduction, which I'm perfectly happy with.
    1995 GMC Yukon 4WD 4DR
    5.3 "LMG" engine: E85 with AFM
    6L80e 6 speed automatic transmission
    Oct 2003
    Interesting. What was the parameter for engine torque management B1901?
    PowrMax Performance
    100 mm PowrMAF
  1. Got the DSP 5 Problem Solved!!!
    By LBZoom in forum Duramax LB7
    Last Post: March 29th, 2009, 04:06 PM
  2. loss of power
    By willy1375 in forum Duramax LB7
    Last Post: February 23rd, 2008, 04:53 PM
  3. Power loss at 6250rpm for no obviously reason!!!
    By rally1 in forum Gen III V8 Specific
    Last Post: November 2nd, 2007, 10:36 PM
  4. A/C Fan power table pressures too high?
    By JohnW in forum Gen IV V8 Specific
    Last Post: June 8th, 2007, 03:19 AM
  5. loss of power help
    By zone in forum General (Petrol, Gas, Ethanol)
    Last Post: May 23rd, 2006, 04:26 AM
