Everything looks and sounds good at startup and the NB O2s for both banks are in agreement. After 20 seconds or so, bank 2 starts to drop. Once it goes into closed loop the strims will work their way up to 30% difference between the banks. If I turn the key off and restart, the pattern repeats. Good for the first 20 seconds. With only 5* of overlap on the cam, idle is smooth at startup, but it gets sightly lumpy after running the 20 seconds.
I have tried swapping O2s, new O2s, and swapping the injector drivers around, all with no effect on this. The idle is more chunky in this first startup vid, but I found that one of the drivers had a bad transistor. Fixed that.
Ignore the widebands, I'm still trying to get these damn LC1s to work properly. Not sure if the bank assignments match up to the NBs any more at this point. Ignore the IAT as well, I have to make up an extended sensor. It is barely protruding through the huge mass off aluminum at the front of the lower intake.
Log and tune files are attached below. I turned the key off a couple of times during the log.
