Results 1 to 4 of 4
Thread: FUELQ_MAIN_DMA doesn't show up
    Mar 2009
    Default FUELQ_MAIN_DMA doesn't show up
    When I log with the V2 by itself I select the FUELQ_MAIN_DMA Main Injection Fuel Flow Rate 2 PID and it shows up on the V2 while logging, but when I upload them to the PC to play them back it doesn't show up on the PC. All of my others seem to come through except this one. Am I doing something wrong? The vehicle is my 95 SUBURBAN with an 01 DURAMAX/ALLISON in it.
    You're not doing anything wrong.
    There is a bug in the DMA PID handling between BBL and the Scan Tool software. If has been fixed in the next update. Which is due out within the next few days.
    Mar 2009
    I just wanted to make sure it wasn't me. I'm new to EFILIVE and still trying to learn it all.
    Dec 2007
    Thanks Paul. Good to see these fixes making it in.
  1. Show me your A0014's
    By vetteboy2k in forum Custom Operating Systems
    Last Post: November 26th, 2012, 01:26 AM
  2. how much max, NA, WOT air flow (g/s) does your log show?
    By LS1-450 in forum Gen III V8 Specific
    Last Post: June 20th, 2008, 03:13 AM
  3. Show off your timing...
    Last Post: August 30th, 2007, 02:08 AM
  4. Vin # in tune does not show the same as my vin...
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: February 11th, 2007, 10:04 AM
