Im looking into using the flex fuel system to change the fuel and spark maps to suit a Liquid LPG setup on an E38 controlled LS2.
I have only recently discovered the flex fuel so im not sure exactly how it effects engine operation, does it only adjust fuel and spark maps? or is there other changes made.
how much control over the system do I have with EFIlive? can I see and adjust all tables and modifiers related to flex fuel? can I use the fuel composition sensor input as a switch? can I use the input to sense LPG temp and modify the fuel map accordingly?
I been searching for as much info as I can find on flex fuel but there is next to nothing available. can anyone point me in the direction of somewhere or someone who knows the ins and outs of the system and its capabilities.
thanks
