I set the PID selections with EFILive Scan and Tune 8.1.2 Build 58, and program them to the FlashScan from there. I have it log FUEL_MAIN_M "Main Injection Fuel Flow Rate 2 (mm3)", and it shows up just fine on the FlashScan V2, but it will not show up when I view the log on the computer in EFILive Scan V7.5.
I am trying to view the log with EFILive Scan 7.5.5 Build 88. All other PIDs show up just fine, but the FUEL_MAIN_M (or anything similar) does not show up in the "PIDs (F8)" or "Data (F9)" tab. If I try and select "Main Injection Fuel Flow Rate 2" (FUELQ_MAIN_DMA), I get the error in the attached screenshot.
How can I get the "Main Injection Fuel Flow Rate 2" parameter to be logged? The only way this works is to log with the laptop, but I would really like to be able to do black-box logging.
