Is there a way to change the engine size that is displayed in the Calibration Tab? The engine size box is "Grayed out" but, I would like to alter it for non stock engine sizes. I know this has nothing to do with the engine size in the tune.
Jeff
Jeff
Look for and/or change the B0104 cylinder volume parameter to change the engine size.
The actual engine display size in the calibration window is just a descriptive field that EFILive displays based on the most common application for the loaded tun file. Obviously that value has no bearing on the actual tune.
Thanks Paul,
I kind of figured it wasn't editable because it is grayed out. I just thought I would check.
Jeff
