Results 1 to 6 of 6
Thread: What PIDS should I select?
    Junior Member LM7Tuner's Avatar
    Sep 2009
    Default What PIDS should I select?
    What PID's should I select other than the basics for your dash(VSS, RPM, ECT, Spark, Fuel Trim, AFR, Knock Retard, IAT, Throttle, MAP, MAF, Fuel Trim, Injector Duty Cycle, Fuel Status,) for tuning purposes? This will be for a all around engine and transmission tune.
    RPM
    AFR
    DYNCYLAIR_DMA or DYNCYLAIR
    DYNAIR
    MAF
    MAFFREQ
    MAP
    TP
    ECT
    IAT
    LONGFT1 and 2
    SPARKAVD
    KR
    GEAR
    TCCMODE
    TFMPRS
    VSS
    Serial wideband:
    WBO2AFR1 or 2
    BEN1 or 2
    Analog wideband:
    AD1 or 2
    AFR_xxx1 or 2 (xxx = your wideband model)
    BEN_xxx1 or 2
    Make sure pid channel count does not go over 24 (otherwise your sample rate will go down).
    Sep 2009
    SAE.MAF or GM.MAF
    Sep 2009
    GM.TP or SAE.TP
    SAE.TP
    Same as tables D0901,2,3,6,7,8.
    Sep 2009
    Ok thanks.
  1. How to select mutliple cells in a row to smooth?? but not all of the cells.
    By 2010 Bumblebee in forum General (Petrol, Gas, Ethanol)
    Last Post: April 29th, 2010, 02:34 PM
  2. Can't select RAFIG PID's in either BBL or Scan tool!
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 22nd, 2009, 01:53 PM
  3. cant select pids ini not found error message
    By Gelf VXR in forum FlashScan V2 BB Logging
    Last Post: September 3rd, 2008, 11:02 AM
  4. Cylinder Select?
    By WopOnTour in forum Tips and tricks
    Last Post: May 31st, 2005, 11:02 AM
