What are others doing as far as tow/haul mode on engine swaps? I know GM hooked the switch to the BCM and then transmits it over the class 2 data bus to the ECM or TCM to engage it it. Has anybody found a way to engage it without the BCM? Is there a simulator or something out there that will act as the BCM? I have everything worked out on my DURAMAX/allison swap except for this roadblock and I am trying to get past it.
