Results 1 to 10 of 18
Thread: Lean Cruise with COS5?
    Feb 2013
    Default Lean Cruise with COS5?
    I'm currently running COS5 2bar OLSD, but will probably go to the semi-open loop (SOLSD) soon once the VE table is good.
    Lets say I have B3647 set to 1.0 in the cruise area, so normally it would be in SOLSD. And I have lean cruise enabled to remove 0.09 from the EQR (gives ~15.6 AFR assuming E10). Once the lean cruise enablers are met, will it completely ignore B3647 and also no longer attempt to use the STFT's for trimming?
    2001 Silverado 5.3L ECSB 2WD T56:
    T76 turbo, Meth injection, 72# injectors, 799 heads, 212/212 114LSA cam, Built 4L80E, 3.42's
    EFILive V1 Commercial, COS5 2-bar SOLSD, AEM wideband
    Jan 2012
    I just have my commanded fuel tables command richer in my cruise tables. I have my tune posted in my g/cyl thread if you want to take a look at how mine is. But I'm running a cos3
    2011 Cadillac Escalade ESV. BTR 218/224 .553/.553 110LSA. Built 6L80 with 278mm Circle D 2800 stall converter.
    Feb 2013
    You're doing a rich cruise?
    Jan 2012
    Oops. I ment lean. Commanding 15.6. I like to keep my tunes simple. I don't like having to rely on other tables to trigger to get the lean cruise to activate.
    Feb 2013
    Yeah that would be simpler, but I like the idea of setting the speed and ECT enablers for lean cruise so its not trying to go lean while puting around town and bucking.
    Just want to make sure the semi-open loop isn't going to try to be active during lean cruise.
    Oct 2006
    I ran a COS3 tun with Lean Cruise. Seemed to work fine.
    2006 Trailblazer
    Jan 2012
    No surging issues here. My rpm/mph and kpa is very predictable and makes it easy to tune that way
    Feb 2013
    Quote Originally Posted by andysc3 View Post
    With a manual gearbox the surging/bucking is far more noticeable. Decelerating when lean is the worst. I need to richen up decel or re-enable DFCO.
    Jan 2012
    Mine goes rich on decel. I need to figure that out. It does down to 11.5-12.5. But I'm running FIC 1000cc injectors and I can't control the min pulse with
    Feb 2013
    Yeah I had that issue too with their injectors, their data is not correct. Pm me for more info.
  1. lean cruise 5.3
    By johnt9559 in forum Tuning For Economy
    Last Post: February 21st, 2012, 05:04 AM
  2. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  3. COS3 and COS5 lean cruise PE Mode AFR error
    By ringram in forum Custom Operating Systems
    Last Post: August 16th, 2007, 07:25 PM
  4. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 09:42 PM
  5. Rich cruise in COS5
    By 5.7ute in forum Custom Operating Systems
    Last Post: June 6th, 2007, 01:24 PM
