View Poll Results: Flex Fuel for LS1 F&Ybody
Voters
9. You may not vote on this poll
  • Yes: This would be a great addition.
    8 88.89%
  • No: There is no need for this.
    1 11.11%
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Flex Fuel for LS1
  1. #11
    Aug 2006
    Quote Originally Posted by Tre-Cool View Post
    Been a few years and with the ethanol sensor's now pretty cheap at around $70 and ethanol stations springing up more and more, figured i'd ask.
    I'd prefer to go this path than convert to the 1mb ecu if I could help it, especially when i'd have 4 cars to do.
    Why not just convert one of your vehicles to the 1mb PCM and see if you like it. The 512kb and 1mb PCM pinouts are just about identical. About the only difference I have seen is the O2 sensor ground/low reference wiring. Some calibrations are set up for the low ref to return to the PCM and some get grounded through the harness. A simple deletion of codes takes care of that.
    Jeff
  2. #12
    Oct 2011
    is there options for us 4x guys running a 411 to get a flex fuel ecm installed?
  3. #13
    Aug 2006
    I don't know about the 4x/1x engines running the 512 kB PCM. Flex Fuel was only in the 24x engines (As far as I know). I wish I had an engine test stand. It would be interesting to see if it could be figured out in HEX how to change a 24x calibration to work in a 4x engine. That would be cool if it were/is possible. That would open up Many,Many options.
    Jeff
  4. #14
    Feb 2006
    Quote Originally Posted by Lextech View Post
    Jeff
    Allready ahead of you there. I put one in my car and then found the battery was completely dead. lol. mind you I haven't driven the car in 5 months. Also need to finish off changing pulleys over for the blower.
    Quote Originally Posted by wyochimneysweep View Post
    There is a factory OS/CAL you can use in efilive that has flex fuel support. But... If you want flex fuel and boost 2bar support you need hpt. Unless you swap to the 1mb like I am going to test.
    My main reason for doing it is for our drag cars, I already have ethanol sensors on them to keep an eye on the %, but they are boosted motors so I still need 2 bar support.
  5. #15
    Oct 2011
    do you have the os/cal for flex fuel support? not boosted yet but if I do go boosted ill be going 24x
  6. #16
  1. Looking for the flex fuel pin in a e40
    By 1meangto in forum Gen IV V8 Specific
    Last Post: November 16th, 2017, 07:50 PM
  2. E38 Flex Fuel OS ???'s
    By GAMEOVER in forum E37, E38 & E67 PFI ECM's
    Last Post: November 3rd, 2009, 04:40 PM
  3. Looking for a 3.5L or 3.9L Flex Fuel tune
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2009, 01:04 PM
  4. Flex fuel sensor
    By vzsv8 in forum Gen III V8 Specific
    Last Post: February 24th, 2009, 11:35 PM
  5. Converting a NON-Flex fuel vehicle to Flex fuel??
    By kbracing96 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2008, 06:15 AM
