Hi all, this is my 1st boosted E38 and kicking my rear, it's a turbo 2010 Camaro L99, a fellow tuner told me to tune through the MAF and the MAF curve is ugly now the idle is not to smooth and light throtle is a bit jerky after that it seems to run ok WOT AFR looks ok but like I said the MAF curve is ugly and around 5500 RPM seems to loose control of the fuel can not get the AFR below 11.8 checking the fuel presure in the AM, FYI 10psi, GT500 injectors, MAF is in a blow through 4" pipe before T/B, and no resinator in the exhaust other wise stock. Thanks for any help, Justin
